In many industrial applications, collecting and managing sensor data can be a significant challenge. Traditional data logging solutions often require dedicated hardware, complex software, or external cloud services, which can increase costs and introduce network dependencies. This article introduces a powerful Node-RED flow designed to solve these challenges by transforming an Enterprise IIoT Gateway into a local data logging and management hub. This flow automatically saves sensor data to CSV files directly on the gateway, providing a reliable and accessible local logger. Furthermore, it includes an intuitive dashboard that allows users to easily view, download, and manage these historical data files from any PC on the same network, ensuring you have complete control over your data without relying on external services.
To successfully follow and implement the steps outlined in this guide, you will need the following components and software:
Hardware:
- An Industrial IoT Wireless Sensor (s).
- An Enterprise IIoT Gateway or an Enterprise IIoT Gateway Lite.
- A computer equipped with Wi-Fi or Ethernet connectivity to connect to the Enterprise IIoT Gateway and access Node-RED.
Software:
- Node-RED: (Pre-installed on the Enterprise IIoT Gateway)
- NCD Library: (Pre-installed on the Enterprise IIoT Gateway)
- FlowFuse Dashboard 2: This must be installed as per the instructions provided in its documentation.
Install Dashboard
Source: https://dashboard.flowfuse.com/
Step 1. Open the menu in the top-right of Node-RED, then Click “Manage Palette”:
Step 3. You must confirm the installation by clicking on the Install button in the pop-up window.
Step 4. You will see a list of the dashboard 2 nodes that have been installed.
Step 5. In workspace you can see the available nodes in the nodes palette, as shown in the following image:
See the following GIF for a visual demonstration of the installation process:
Importing Flow
Next step is to import the flow, which has been specifically designed and optimized for seamless integration with NCD sensors. The import process is straightforward; however, it is essential to follow these steps carefully:
Step 1. Click on the following link to access the NCD Json Flow source code:
Step 8. Click on Deploy button in order to save and apply the changes.
Accessing Dashboard
After successfully configuring and deploying your nodes, the next step is to access the interface. This is where the NCD Dashboard elements are displayed.
Step 3. Once you open the dashboard, you’ll see several components designed to help you manage your sensor data.
Select Device: This dropdown lists all the MAC addresses of the sensors that have transmitted data since the last deploy. Use this to select the specific sensor whose data you wish to download or manage. If your sensor’s address isn’t listed, it means the flow hasn’t received any data from it yet.
Select Date: This is a date picker widget. Use it to select the specific date of the CSV file you want to download. The flow will look for a CSV file with a timestamp matching the date you choose, so be sure to pick a valid date when the sensor was active.
Download CSV Button: Clicking this button will initiate the download of the selected CSV file. If the file exists, it will be saved to your local PC’s downloads folder. If the file doesn’t exist for the selected device and date, you’ll receive an error message indicating that the file was not found.
Delete CSVs for This Device Button: This button is a powerful tool for managing storage. Clicking it will permanently delete all CSV files associated with the currently selected device. Use this after you’ve downloaded your files to free up memory on the gateway.
Delete All Files Button: This button will delete all CSV files stored on the Enterprise IIoT Gateway, regardless of the device. Use this with caution, as it will erase all historical sensor data.
Downloading Your First File
Once your sensor starts transmitting data, its MAC address will appear in the Select Device dropdown. Simply select the device, choose your desired date, and click the Download Button to get the file on your PC.
CSV File Header
TIME | FIRMWARE | COUNTER | BATTERY PERCENT | RSSI | SENSOR_DATA
You Might Also Like
SORBA AI – NCD Sensors Integration Guide: Complete Setup, Configuration and Data Visualization
Using Node-RED to Expose Sensor Data into Modbus TCP Registers on the Enterprise IIoT Gateway
Enterprise Line Industrial IoT Sensors: FAQ
Case Study: Modernizing 1970s Machinery for Real-Time Production Tracking
