CUSTOM FIRMWARE – CIRCUIT BOARD MODIFICATION – ENCLOSURES – LOGO PRINTING
Fully customized solutions for your specific application based on our preexisting designs
Your exact need with easy installation, reduced wiring, smaller size, less power consumption and lower production cost
Your exact needs with easy installation, reduced wiring, smaller size, less power consumption and lower production cost.
Company branding on the boards as well as full color printing of your company logo printed on the enclosure.
We stay in constant communication with you throughout the entire design and manufacturing process.
As an American manufacturer we are here to support the products we make.
With more than 20 years of experience in electronics design and manufacturing, NCD’s engineers can build a customized solution for you based on the designs you see on our website. We can combine devices onto a single board, change the shape, or even the components to meet your exact needs with many advantages such as reduced wiring, easy installation, smaller size, less power consumption, and in many cases, an overall reduction in production cost.
NCD offers full-spectrum design including white label enclosures with the option of full-color printing of your company logo on the top.
NCD engineers will communicate with you throughout the entire process. We will design and manufacture the circuit boards then build and test a working sample. Once it meets your requirements, we will begin production.
An efficient operation through monitoring and prevention with fewer repairs and less downtime
Greatly decrease downtime spending with increased efficiency and higher productivity
NCD will help you with a fully customized solution so you can achieve your specific goal
I
I
I
I
I
I
I
I
I
I
I
I
I
I
I
I
Custom designs should be based on an existing product.
Custom engineering fees depend on your requirements, so please contact us for a quote!
We maintain ownership of all designs as they are based on our existing design.
We will only ship the customized product to you or your authorized agents.
We have an NDA available if needed.
Custom projects are noncancelable, non returnable and non refundable.
Minimum quantity is 25 units.
Turn-around time is about 2-3 weeks.
We only ask that our customers prototype using our existing products before we customize.
We are a United States manufacturer so we are here to support the products we make.
We design, assemble, test, and package IoT hardware for our clients worldwide.
I normally don’t respond to “survey” type questions. However, I was so pleased with the performance of your product I felt I should respond.
Our original plan was to install a PLC and Panelview for remote operation of a gate. Plan “B” was to use your Relay Controllers. We installed your Relay Controllers last week and everything worked as expected. We probably saved $10K using your devices.
The NCD Enterprise line of sensors has been great to work with. The ease of installation of both the Gateways and the sensors themselves has helped us deploy quickly to customer locations.
The all-in-one maintenance sensor is great for tracking multiple performance parameters on machinery. Vibration, Temperature and Amperage, can each alone find fault, and when considered together start to form a powerful picture of what is happening with an Asset.
Your relays are a great product. They are dependable and last long in all temperatures. We have been using them for over 4 years and we have not seen a single one fail. We do have one issue to report.
weborders@ncd.io
+1 866 960 1270
430 Market St
Osceola, MO 64776
