- An 2 Channel Industrial Wireless Thermocouple High Temperature Sensor
If you are using Node-Red through something other than our Enterprise Gateways you can setup your Node-Red to connect to your modem and skip to the Sensor Hardware section.
Enterprise Gateway Setup
- 1 x Enterprise Gateway
- 2 x WiFi Antennas
- 1 x Digimesh Antenna
- 1 x Din Rail Adapter
- 1 x Power Supply
- 1 x Two Position Terminal
- 1 x Three Position Terminal
- 1 x Eight Position Terminal
Sensor Hardware Setup
- Use the 2 Channel Industrial Wireless Thermocouple High Temperature Sensor Datasheet for reference on where and how to attach the probes
- Turn on the sensor
Software Setup​
Final Steps
