- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Default Configuration
| Network ID | 7F FF (HEX) |
| Node ID | 0 |
| Delay | 600 (DEC) seconds |
| Power | +24 dBm |
| Retries | 10 |
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 23,
"sensor_data": {
"channel_1":111,
"channel_2":130
"sensor_name": "2-Channel Thermocouple",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
- channel_1
- The measured temperature in Celsius for channel 1
- channel_2
- The measured temperature in Celsius for channel 2
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 23,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 23,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 23,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 23,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 23,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 23,
"sensor_data": {
"channel_1":111,
"channel_2":130
"original": {...},
"payload": {
"channel_1":111,
"channel_2":130
"_msgid": "48e99332fc104565"
- channel_1
- channel_2
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
*Required
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Sensor Specific Configuration
Set Thermocouple Type
This command allows you to set the type of thermocouple sensor probe connected. Thermocouples are available in different metal combinations and calibrations, offering a variety of temperature measurement options.
Possible parameter values:
0x00 — K Type
0x10 — J Type
0x20 — T Type
0x30 — N Type
0x40 — S Type
0x50 — E Type
0x60 — B Type
0x70 — R Type
Set Filter Level
This command allows you to set the filter level applied to the sensor data.
0x00 — Level 0
0x01 — Level 1
0x02 — Level 2
0x03 — Level 3
0x04 — Level 4
0x05 — Level 5
0x06 — Level 6
0x07 — Level 7
Set Cold Junction Resolution
This command allows you to set the resolution for cold junction compensation. Cold junction compensation adjusts for the thermoelectric voltage missing due to the fact that the thermocouple’s cold end at the instrument is not at the reference temperature of 0°C (32°F).
0x00 — 0.0625⁰C
0x80 – 0.25⁰C
Set ADC Resolution
This command allows you to set the ADC (Analog-to-Digital Converter) resolution for the thermocouple. The available resolution options are 12, 14, 16, and 18 bits.
0x00 — 18 Bits
0x20 — 16 Bits
0x40 — 14 Bits
0x60 — 12 Bits
Set Number of Samples
This command allows you to set the number of samples the sensor will take before sending the data.
0x00 — 1 Sample
0x04 — 2 Samples
0x08 — 4 Samples
0x0C — 8 Samples
0x10 — 16 Samples
0x14 — 32 Samples
0x18 — 64 Samples
0x1C — 128 Samples
Set Measurement Type
This command allows you to set the measurement type for the probe. The available options are: Cold Junction, Hot Junction, and Delta.
0x00 — Cold Junction
0x01 — Hot Junction
0x02 — Delta
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 23 – 2-Channel Thermocouple Notification
- Click on Import
Example Flows
