Industrial Wireless Thermocouple High Temperature Sensor User Manual
NCD Industrial Wireless Thermocouple High Temperature sensor is capable of measuring extreme high and low temperatures.  This Industrial wireless thermocouple temperature sensor includes one K-Type thermocouple connector. An optional XCIB K Type thermocouple from Omega.com with a 3 foot cable and 20 AWG connection is available as an option, rated for temperature measurement applications up to 1090°C (2000°F) with an accuracy of ±1.1°C. This Industrial wireless thermocouple device comes with K-type connector, which can be used to connect a higher temperature range thermocouple if needed. This sensor includes integrated hot and cold junction to provide highly accurate readings.  This  Industrial wireless thermocouple transmitter is ideal for high temperature measurements, industrial boiler temperature measurements, liquid temperature measurement, and temperature monitoring of food storage units.  This Industrial wireless thermocouple sensor is designed to consume extremely low power and send data at extremely long distances of up to 2 miles line of light or 28 miles using high gain antennas.
  • Industrial Long Range Wireless Thermocouple Transmitter
  • K type thermocouple Connector
  • Optional High Grade Probe with an Accuracy of ±1.1°C
  • NO Monthly Fee or Locked Proprietary Protocols, Open Node-RED library for ease of configuration and data processing
  • Small 3″ x 3″ Form Factor Wireless IoT Thermocouple Sensor
  • Power-Efficient Sleep Mode, Up to 10 Year Battery Life
  • Includes Battery Level with Every Transmission
Hardware Controls
Power Switch
  • Battery Power
  • Off
  • External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
  • Configuration Button Pressed and held immediately after reset for
    • < 2 second – device starts normally in RUN Mode
    • 2 to 15 seconds – device goes into Configuration Mode
Click to enlarge
Default Configuration
ParametersDefault Value
Destination Address00 00 FF FF (HEX)
Network ID7F FF (HEX)
Node ID0
Delay600 (DEC) seconds
Power+24 dBm
Retries10
Wireless Gateway Nodes
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 04,
    "sensor_data": {
         "temperature":111
    "sensor_name": "Thermocouple",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
  • temperature
    • The measured temperature in Celsius
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
    • Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 04,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 04,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 04,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 04,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 04,
    "nodeId": 0,
    "mode": "FLY",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
  • topic
  • payload
  • time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
Click to enlarge
Wireless Device Nodes
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 04,
    "sensor_data": {
         "temperature":111
    "original": {...},
  "payload": {
         "temperature":111
  "_msgid": "48e99332fc104565"
msg.payload Breakdown
  • temperature
  • topic
  • payload
  • payload.x
  • time
  • addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
  • topic
  • time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes​
  • Serial Device for Config
  • Mac Address
  • Sensor Type*
  • Auto Config
*Required
General Sensor Configurations
  • Wait for Network Formation
  • Destination Address
  • Network ID
  • Node ID and Delay
    • Node ID
    • Delay
  • Power
  • Retries
Sensor Specific Configuration
Set Thermocouple Type
This command allows you to set the type of thermocouple sensor probe connected. Thermocouples are available in different metal combinations and calibrations, offering a variety of temperature measurement options.
Possible parameter values:
0x00 — K Type
0x10 — J Type
0x20 — T Type
0x30 — N Type
0x40 — S Type
0x50 — E Type
0x60 — B Type
0x70 — R Type
Set Filter Level
This command allows you to set the filter level applied to the sensor data.
0x00 — Level 0
0x01 — Level 1
0x02 — Level 2
0x03 — Level 3
0x04 — Level 4
0x05 — Level 5
0x06 — Level 6
0x07 — Level 7
Set Cold Junction Resolution
This command allows you to set the resolution for cold junction compensation. Cold junction compensation adjusts for the thermoelectric voltage missing due to the fact that the thermocouple’s cold end at the instrument is not at the reference temperature of 0°C (32°F).
0x00 — 0.0625⁰C
0x80 – 0.25⁰C
Set ADC Resolution
This command allows you to set the ADC (Analog-to-Digital Converter) resolution for the thermocouple. The available resolution options are 12, 14, 16, and 18 bits.
0x00 — 18 Bits
0x20 — 16 Bits
0x40 — 14 Bits
0x60 — 12 Bits
Set Number of Samples
This command allows you to set the number of samples the sensor will take before sending the data.
0x00 — 1 Sample
0x04 — 2 Samples
0x08 — 4 Samples
0x0C — 8 Samples
0x10 — 16 Samples
0x14 — 32 Samples
0x18 — 64 Samples
0x1C — 128 Samples
Set Measurement Type
This command allows you to set the measurement type for the probe. The available options are: Cold Junction, Hot Junction, and Delta.
0x00 — Cold Junction
0x01 — Hot Junction
0x02 — Delta
Serial Connection
  1. Name
  2. Modem Type
  3. Serial Port
  4. Baud Rate
  5. Network ID
    • The default value is 7FFF
TCP Socket Connection
  1. Name
  2. Modem Type
  3. TCP Port
  4. IP Address
  5. Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Press and release the RESET button and then immediately hold the CFG button for > 15 seconds
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
  2. Import
  5. Expand Type 04 – Thermocouple
  8. Click on Import
Example Flows
