Feature
Specifications | Minimum | Nominal | Maximum | Notes |
Width | 3.28" | |||
Length | 4.30" | |||
Height | 2.16" | |||
Enclosure Rating | IP65, NEMA 1,2,4,4X,12,13, UL-508 | |||
Mounting | 1/4 NPT 1/4-28 UNF Magnet Mount | |||
Temperature Rating | -40° C | 23° C | 85° C | Component Rating |
Tested Temperature | 0° C | 23° C | 40° C | As Tested by NCD Staff |
Probe Temperature | -40° C | 23° C | 105° C | As Tested by NCD Staff |
Parameter | Minimum | Nominal | Maximum | Notes |
Trace Width | 0.007 inch | 0.012 inch | 0.25 inch | Trace Width depends on the Trace Type |
Layer Count | 2L - Rigid | Top and Bottom Layer | ||
Material Type | FR-4 TG170 | FR-4 TG170 | FR-4 TG180 | |
Surface Finish | ENIG 2u" | |||
IPC Standard | IPC CLASS 2 | |||
Finished Copper Foil | 1.0/1.0 OZ | |||
Finished Thickness | 0.062 inc | |||
Fine line <4.0/4.0mil | No | |||
Blind & Burried Vias | No | |||
Non-Conductive Resin | No | |||
RF Module Specifications
Parameter | 868MHz | 900MHz | 2.4GHz |
Frequency Band | 863 MHz to 870 MHz | 902 to 928 MHz | ISM 2.4 GHz |
Transmitter Power | Up to 13 dBm ERP | Up to 24 dBm | Up to 8 dBm |
Receiver Sensitivity | -106 dBm at 80 Kbps | -101 dBm at 200 Kbps | -103 dBm at 250 Kbps |
Range (dense urban) | ~1000ft | ~1000ft | ~300ft |
Range (line of sight) | ~2 miles | ~2 miles | ~1 mile |
Data Rate | 80 Kbps | 200 Kbps | 250 Kbps |
Networking Protocol | Digi XBee® DigiMesh® | Digi XBee® DigiMesh® | Digi XBee® DigiMesh® |
Encryption | 128-bit AES | 128-bit AES | 128-bit |
Reliable Packet Delivery | Retries/acknowledgements | Retries/acknowledgements | Retries/acknowledgements |
IDs | PAN ID and addresses, cluster IDs and endpoints (optional) | PAN ID and addresses, cluster IDs and endpoints (optional) | PAN ID and addresses, cluster IDs and endpoints (optional) |
Certification | CE/RED, ROHS Compliant | FCC (America), IC (Canada), C-Tick (Australia), Anatel (Brazil), IDA (Singapore) | FCC (America), IC (Canada), RCM (Australia), Anatel (Brazil), Teleck MIC (Japan), KCC (South Korea) |
Powered by a single 16000mAh battery.
Batteries size | 16000mAh | This device has a single D-Cell (LR20) battery | ||
Battery Life 1 TPD | 10 Years | TPD Transmissions per Day | ||
Battery Life 12 TPD | 8 Years | TPD Transmissions per Day | ||
Battery Life 24 TPD | 5 Year | TPD Transmissions per Day | ||
Battery Life 96 TPD | 3 Year | TPD Transmissions per Day |
2 Channel Industrial IoT Wireless Thermocouple Temperature Sensor.
