Standalone Smart Vibration Sensor Gen4 Quick Start Guide
  1. A Standalone Smart Vibration Sensor Gen4
Enterprise Gateway Setup
  • 1 x Enterprise Gateway
  • 2 x WiFi Antennas
  • 1 x Digimesh Antenna
  • 1 x Din Rail Adapter
  • 1 x Power Supply
  • 1 x Two Position Terminal
  • 1 x Three Position Terminal
  • 1 x Eight Position Terminal
  2. The device is a self-contained one, all sensor, buttons, etc. are built into the housing. You don’t need to attach anything except for mounting it to the equipment
  3. The sensor ships turned on, there is no need for you to power it
    • You can reset/configure it via reed switches, see section Hardware Controls of the User Manual for more information
  4. Move the sensor to where it is at least 3 feet or 1 Meter from the gateway to ensure optimal connectivity.
Software Setup
  5. Trigger the Magnetic RESET Switch using a magnet.
Final Steps
  1. Install the sensor at the desired location.
