Industrial Wireless 3 Channel Production Counter Quick Start Guide
  1. A 3 Channel Production Counter
Enterprise Gateway Setup
  • 1 x Enterprise Gateway
  • 2 x WiFi Antennas
  • 1 x Digimesh Antenna
  • 1 x Din Rail Adapter
  • 1 x Power Supply
  • 1 x Two Position Terminal
  • 1 x Three Position Terminal
  • 1 x Eight Position Terminal
  2. Attach Antenna to the sensor’s RP-SMA connector
  3. Attach any probes you will use
  4. Open the lid of the sensor by removing the 4 screws on top
  5. Turn on the sensor
    • If using battery power set the power switch to ON BAT
    • If using external power set the power switch to ON EXT
    • See section Hardware Controls of the User Manual for more information
  6. Press the CFG Button to check for power
    • If the TEST LED lights up while the CFG button is held down the sensor is powered
    • If the TEST LED does not light check the batteries or power supply to the board
Software Setup
  5. Press the RESET Button on the Sensor Hardware
Final Steps
  1. Close the lid of your sensor using the 4 screws to attach the lid
