Explore the 3 Channel Production Counter Capabilities
The 3 Channel Production Counter is a device specifically designed to track production counts and machine uptime events in industrial settings. It is a flexible device that can be configured to observe one or more events via different input types – break beam sensor, photo eye sensor, reflector sensor, dry contact closure, and wet contact closure.
It has long range wireless capabilities utilizing robust Mesh networking protocols with high level of security and network reliability. It is compact, durable, and powered by long-lasting batteries.
- Industrial Grade Production Count Monitoring
- Measure Production Uptime
- Measure Number of Cycles
- Dry Contact Closure Input
- Wet Contact Closure Input
- Beam Break and Photo Eye Sensor Input-Based Event Detection
- Humidity Range 0–90%
- For Indoor and Outdoor Use
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Probe Operating Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Inputs | Digital, Acceleration, Magnetic, Current | |||
| Opto-input Voltage | 3.3 V | 24V | ||
| Reporting interval | 5 seconds | 600 seconds | 16777215 seconds | How often data is transmitted wirelessly |
| Range of counter values | 1 | 4294967295 | The maximum number of events the sensor can count to | |
| CT Current | 1.5% FS | FS | Minimum current read by the CT. CT range 100 to 1000Amp |
RF Module Specifications
Probes Specifications
Digital Inputs
The Industrial Digital Input and Sensor Reader is a compact and robust device tailored to interpret signals from various digital inputs and sensors prevalent in industrial settings, including brake beam sensors, photo reflectors, photo eye sensors, and on/off signals. It can also work with counter with a digital pulse outputs to easily integrate with existing equipment in production lines or plants for example.
With high accuracy and reliability, it offers real-time data acquisition and monitoring, seamlessly integrating into existing industrial automation systems. Its user-friendly interface and flexible configuration options ensure easy setup and compatibility with diverse applications, enhancing operational efficiency, equipment reliability, and production optimization. Ideal for conveyor systems, packaging machinery, and robotic systems, it empowers industrial operators with streamlined data interpretation and control capabilities, minimizing downtime and maximizing productivity.
Probe Configuration and Wiring
Diagram Examples
- This device is Powered by a single D-cell (LR20) battery
While changing the batteries:
- Turn off the sensor
- Only use a new D-cell battery (obtain one from NCD, as it has a built in supercapacitor, this is not a regular battery).
- Make sure to align the connector in the proper orientation (this will assure you match the polarity)
- The battery should not be replaced in fire-risky areas
- Do NOT install a rechargeable battery
Head to the NCD store if you want to purchase the 3 Channel Production Counter.
