- An Industrial IoT Wireless Air Quality CO2 Temperature Humidity Particulate Matter Sensor
Enterprise Gateway Setup
- 1 x Enterprise Gateway
- 2 x WiFi Antennas
- 1 x Digimesh Antenna
- 1 x Din Rail Adapter
- 1 x Power Supply
- 1 x Two Position Terminal
- 1 x Three Position Terminal
- 1 x Eight Position Terminal
- Use the Industrial IoT Wireless Air Quality CO2 Temperature Humidity Particulate Matter Sensor for reference on where and how to attach the probes
- Turn on the sensor
Software Setup​
Final Steps
