Industrial IoT Wireless Air Quality CO2 Temperature Humidity Particulate Matter Sensor User Manual
Introducing NCD’s Long Range Industrial IoT Wireless CO2, Temperature, Humidity, and Particulate Matter Sensor for air quality monitoring. It features a range of up to 2 miles using wireless mesh networking, transmitting CO2 concentration, particulate size, mass, temperature, and humidity data at customizable intervals.
The sensor uses CMOSens® Technology for precise CO2 measurement, along with NDIR technology for CO2 detection. It includes a best-in-class humidity and temperature sensor, which compensates for external heat sources without additional components. The dual-channel design ensures long-term stability in CO2 measurement.
The particulate matter sensor measures PM1.0, PM2.5, PM4.0, and PM10.0 particles, which can cause serious health issues like asthma and cardiovascular disease. It uses laser scattering technology for precise measurements and includes a fan for automatic sensor cleaning every 10 transmissions.
The temperature sensor operates from -25°C to 85°C (-13°F to 185°F), while the humidity sensor handles 0-100% RH. Powered by 6 AA batteries, the sensor offers up to 3 years of battery life, with external power options available on request.
  • Industrial Grade Sensor Mass Concentration Range 0-1000 μg/m^3
  • Mass Concentration Resolution of 1 μg/m^3
  • Mass Concentration Size Range PM1.0, PM2.5, PM4.0, PM10.0
  • Number Concentration Range 0 to 3000 1/cm^3
  • Number Concentration Size Range  PM0.5, PM1.0, PM2.5, PM4.0, PM10.0
  • Industrial Grade CO2 Measurement Range 0 – 5’000 ppm
  • CO2 Measurement Accuracy ± (60 ppm + + 5% of reading)(25 °C, 400 – 2’000 ppm)
  • Temperature compensation of CO2 sensor signal
  • Fully calibrated and linearized
  • Unique Long-Term Stability of up to 8 Years
  • Laser-Based Scattering Principle and Advanced Algorithms
  • Built-in Auto Cleaning Feature (internal fan) After Every 10 Transmissions
  • Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
  • Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
  • Encrypted Wireless Communications up to 2 Mile Range in open environments
Hardware Controls
Power Switch
  • Battery Power
  • Off
  • External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
  • Configuration Button Pressed and held immediately after reset for
    • < 2 second – device starts normally in RUN Mode
    • 2 to 15 seconds – device goes into Configuration Mode
Click to enlarge
Default Configuration
ParametersDefault Value
Destination Address00 00 FF FF (HEX)
Network ID7F FF (HEX)
Node ID0
Delay600 (DEC) seconds
Power+24 dBm
Retries10
Wireless Gateway Nodes
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 53,
    "sensor_data": {
         "mass_concentration_1_0": 5
         "mass_concentration_2_5": 9
         "mass_concentration_4_0": 80
         "mass_concentration_10_0": 150
         "number_concentration_0_5": 2
         "number_concentration_1_0": 3
         "number_concentration_2_5": 5
         "number_concentration_4_0": 8
         "number_concentration_10_0": 15
         "typical_size": 10
         "Humidity": 60.53
         "Temperature": 25.78
         "CO2": 421
    "sensor_name": "Air Quality CO2 and Particulate Matter Sensor",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
  • mass_concentration_1_0
    •  The total mass of 1.0µm sized particles in µg/m³
  • mass_concentration_2_5
    •  The total mass of 2.5µm sized particles in µg/m³
  • mass_concentration_4_0
    •  The total mass of 4.0µm sized particles in µg/m³
  • mass_concentration_10_0
    • The total mass of 10.0µm sized particles in µg/m³
  • number_concentration_0_5
    • The total number of 0.5µm sized particles in #/cm³
  • number_concentration_1_0
    • The total number of 1.0µm sized particles in #/cm³
  • number_concentration_2_5
    • The total number of 2.5µm sized particles in #/cm³
  • number_concentration_4_0
    • The total number of 4.0µm sized particles in #/cm³
  • number_concentration_10_0
    • The total number of 10.0µm sized particles in #/cm³
  • typical_size
    • The typical particle size in µm
  • Humidity
    • The relative humidity in %
    • The measured temperature in °C
  • CO2
    • The CO2 value in PPM (parts per million)
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
    • Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 53,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 53,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 53,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 53,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 53,
    "nodeId": 0,
    "mode": "FLY",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
  • topic
  • payload
  • time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
Click to enlarge
Wireless Device Nodes
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 53,
    "sensor_data": {
         "typical_size": 10
         "Humidity": 60.53
         "CO2": 421
    "original": {...},
  "payload": {
         "typical_size": 10
         "Humidity": 60.53
         "CO2": 421
  "_msgid": "48e99332fc104565"
msg.payload Breakdown
  • typical_size
  • Humidity
  • CO2
  • topic
  • payload
  • payload.x
  • time
  • addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
  • topic
  • time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes​
  • Serial Device for Config
  • Mac Address
  • Sensor Type*
  • Auto Config
  • OTF Config
    • Checking the box next to this field AND having Auto Config checked tells Node-Red that the sensor(s) corresponding to this Wireless Device node should be configured when a FLY message is detected
*Required
General Sensor Configurations
  • Wait for Network Formation
  • Destination Address
  • Network ID
  • Node ID and Delay
    • Node ID
    • Delay
  • Power
  • Retries
Set Skip Samples (CO2)
This value determines how many samples for the CO2 reading the sensor skips.
Set Skip Samples (Particulate)
This value determines how many samples for the Particulate matter reading the sensor skips.
Set FLY Rate
You can set the FLY rate (how often the sensor will look for the fly message after transmitting a packet) in hours for the device.
Serial Connection
  1. Name
  2. Modem Type
  3. Serial Port
  4. Baud Rate
  5. Network ID
    • The default value is 7FFF
TCP Socket Connection
  1. Name
  2. Modem Type
  3. TCP Port
  4. IP Address
  5. Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Press and release the RESET button and then immediately hold the CFG button for > 15 seconds
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
  2. Import
  5. Expand Type 53 – Air Quality CO2 and Particulate Matter Sensor
  8. Click on Import
Example Flows
