Introducing NCD’s Long Range Industrial IoT Wireless CO2, Temperature, Humidity, and Particulate Matter Sensor for air quality monitoring. It features a range of up to 2 miles using wireless mesh networking, transmitting CO2 concentration, particulate size, mass, temperature, and humidity data at customizable intervals.
The sensor uses CMOSens® Technology for precise CO2 measurement, along with NDIR technology for CO2 detection. It includes a best-in-class humidity and temperature sensor, which compensates for external heat sources without additional components. The dual-channel design ensures long-term stability in CO2 measurement.
The particulate matter sensor measures PM1.0, PM2.5, PM4.0, and PM10.0 particles, which can cause serious health issues like asthma and cardiovascular disease. It uses laser scattering technology for precise measurements and includes a fan for automatic sensor cleaning every 10 transmissions.
The temperature sensor operates from -25°C to 85°C (-13°F to 185°F), while the humidity sensor handles 0-100% RH. Powered by 6 AA batteries, the sensor offers up to 3 years of battery life, with external power options available on request.
- Industrial Grade Sensor Mass Concentration Range 0-1000 μg/m^3
- Mass Concentration Resolution of 1 μg/m^3
- Mass Concentration Size Range PM1.0, PM2.5, PM4.0, PM10.0
- Number Concentration Range 0 to 3000 1/cm^3
- Number Concentration Size Range PM0.5, PM1.0, PM2.5, PM4.0, PM10.0
- Industrial Grade CO2 Measurement Range 400 – 5’000 ppm
- CO2 Measurement Accuracy ± (60 ppm + + 5% of reading)(25 °C, 400 – 5’000 ppm)
- Temperature compensation of CO2Â sensor signal
- Unique Long-Term Stability of up to 8 Years
- Laser-Based Scattering Principle and Advanced Algorithms
- Built-in Auto Cleaning Feature (internal fan) After Every 10 Transmissions
- Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
- Encrypted Wireless Communications up to 2 Mile Range in open environments
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Sampling Rate | 30 seconds | 20000 seconds | ||
| Mass Concentration range | 0 μg/m³ | 1000 μg/m³ | ||
| Mass Concentration resolution | 1 μg/m³ | |||
| Mass Concentration precision | ±10 % | |||
| Mass Concentration size range | PM1.0, PM2.5, PM4.0, PM10.0 | |||
| Number Concentration range | 0 1/cm³ | 3000 1/cm³ | ||
| Number Concentration size range | PM0.5, PM1.0, PM2.5, PM4.0, PM10.0 | |||
| Temperature resolution | 0.025°C | |||
| Temperature accuracy | 0.3°C | |||
| Relative Humidity range | 0 % | 100 % | ||
| Relative Humidity resolution | 0.04% | |||
| Relative Humidity accuracy | 2% | |||
| CO2 Measurement range | 400 ppm | 5000 ppm | ||
| CO2 Measurement accuracy | 60 ppm + + 5% of reading |
RF Module Specifications
- External power supply (6-18 VDC) Current Requirement 250 mA
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD | 5 Years | TPD Transmissions per Day | ||
| Battery Life 12 TPD | 2 Years | TPD Transmissions per Day | ||
| Battery Life 24 TPD | 1 Year | TPD Transmissions per Day |
Industrial IoT Wireless Air Quality CO2 Temperature Humidity Particulate Matter Sensor.
