VIBRATION SENSORS
NCD IoT Wireless Vibration Temperature Sensor V3
Vibration Sensor Overview
Integrating condition monitoring and vibration sensors into your plant or projects just got easier! Our Industrial IoT Wireless Vibration Temperature Sensor V3 collects an abundance of data including Vibration, Temperature, Frequency, and Velocity so that you may make quick and informed, data-driven decisions.Ā
Easy installation makes collecting data from our Vibration Sensors (and others) quick and safe. After, simply upload your data to our Edge Gateway and send data to your preferred Cloud, User Interface, or Server. You own your data, so there are no monthly fees from NCD. Ever!Ā
Vibration Sensor Features
- Average MAX g Vibration
- RMS Velocity Vibration
- Calculates RMSĀ Displacement
- Peak Vibration Frequency
- Raw Time Domain Data for FFT analysis
- In Built FFT Analysis
- Noise Removal using Low-pass And High Pass Filter
- Frequency Range (Bandwidth) 1.56Hz ~ 3.2kHz
- Frequency Range (Bandwidth) up to 8,000 Hz In Time Domain Mode
- Sample Rate up to 25,600Hz
- Vibration Probe Operating Temperature Range -40 to +125 °C
- Vibration Sensor with External Probe Option
- Multiple Probe Mounting Option 1/4 NPT, 1/4-28 UNF, & Magnet Mount
- Up to 500,000 Transmissions from 6 AA Batteries
A Revolutionary Sensor System
NCD has set out to create an Industrial Vibration + Temperature Sensor to collect all of your crucial data. Save time, money, and resources with our ground-breaking sensors.Ā
Experience
NCD has been in the game for over 25 years. Our unique design and development team are experts, whom strive for quality and excellence.Ā
Made in the United States
All NCD products are designed and manufactured on-site, in the United States. Which means quality, and no long lead times.
Data Ownership
Every bit of data you collect, is YOURS! Simply upload your data to your preferred Gateway, Ā Cloud Service or Server – And there is no monthly fee. Ever!Ā
An EcoSystem of Products
Our products work together to provide you with the data and information you need, to make your projects as efficient as possible.
Flexibility, Security and Peace of Mind
Cloud Agnostic
Our Sensors are adaptable to any of your preferred Cloud Services. Once your data is collected, you may use it with one Cloud Service, or use services interchangeably! Cloud Services include Azure, MQTT, AWS, Google, PC and many more!Ā
Low Cost of Ownership
When we say low cost, we mean NO monthly cost. NCD allows you to upload your data to your preferred Cloud Service/Gateway or Server. Which means no monthly payment.
Five-Year Warranty! Longest in the Industry!
Our products have the industry’s longest warranty. Our product’s quality is unmatched and we’re willing to back that for years to come!
Data Encryption for Peace of Mind
NCD Sensors implement an AES 128 bit encryption system for your security and peace of mind.Ā
prevent. predict. maintain.
Predictive Maintenance Solutions
We have set out to to provide top-of-the-line sensors for all of your Predictive Maintenance and Condition Monitoring needs, no matter the industry or application.
NCD Industrial IoT Wireless Vibration and Temperature Sensor V3 Video
Share this on:
YOU MIGHT ALSO LIKE...ā
Industrial IoT Wireless Transmitter
IntroductionOverview of NCD Long Range Wireless Sensor TransmittersPresenting a Comprehensive List of Essential Features and Compatible Probes.List of the Supported Probes by NCD Industrial IoT Transmitter Device3-Axis Vibration And Temperature ProbeĀ AC Current Sensor ProbeĀ High-Temperature Thermocouple ProbeĀ Temperature / Humidity ProbeAir Quality Sensor ProbeDoor Open/Close ProbeWater Detection ProbePressure Sensor ProbeUltrasound Tank Level ProbeUltrasonic Vibration Sensor ProbeOil Quality Analysis Sensor ProbeĀ CO2 Temperature Humidity ProbeĀ Linear Displacement Sensor LVDTWire Draw ProbeDust Sensor with Temperature Humidity
Ultrasound Sensors for Vibration Condition Monitoring
Predictive maintenance vibration sensors are a proactive approach to maintenance that aims to predict when equipment failure might occur and to prevent it before it does. Ultrasonic sensors are a key tool in predictive maintenance, as they can be used to detect early-stage failures for example in slow rotating machinery which may not be easily detectable with vibration analysis alone. This article will explore the use of ultrasonic sensors in
What is a Wireless Vibration Sensor? Basics, Benefits, Work
Precision and predictive maintenance have become paramount in the context of interconnected industrial systems and machinery. For system integrators tasked with ensuring the smooth operation of complex systems, leveraging advanced technology is essential. One such technological marvel that’s revolutionizing predictive maintenance is the Wireless Vibration Sensor. In this guide, we’ll delve into the basics, benefits, functionality, and essential selection criteria of these sensors to help system integrators make informed decisions
