Introducing NCD’s Ultrasonic Long Range Wireless Tank Level Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating a corrosion resistant Ultrasonic proximity detection sensor, this wireless device transmits highly accurate tank levels as distance values at user-defined intervals. The Ultrasonic tank level sensor features 1mm resolution with a distance measurement range of 40 to 9999mm. Please note the recommended useful range is 500 to 9999mm for best reliability. The Ultrasonic tank level sensor is IP67 rated and comes with a 75 inch (1.9 Meter) probe while the transmitter has a IP65 rating.
Applications requiring 100% reading-to-reading reliability should not use Ultrasonic Tank Level Sensors at a distance closer than 500mm. Although many users have found a Ultrasonic Tank Level Sensor to work reliably from 0 to 50cm for detecting objects, it is not guaranteed to have operational reliability for objects closer than the minimum reported distance. Because of ultrasonic physics, these sensors are unable to achieve 100% reliability at close distances.
Feature
- Industrial Grade Ultrasonic Tank Level Sensor
- Reading-to-Reading stability of 1mm at 1 Meter (typical)
- 500 to 9999mm Measurement Range with 1mm Resolution
- 40 to 499mm Measurement Range with Reduced Reliability
- Target Size Compensation for Greater Consistency and Accuracy
- Fully Calibrated and Linearized with Temperature Compensation
- Long Range Wireless Range of Up to 2 Miles Line of Sight
- 128-Bit AES Encrypted Wireless Communications
- Standard Electrical 3/4 Inch PVC Pipe Fitting
- Supports Smart Percentage Detection Change Mode
- Validates and Retries on Lost Communication Packets
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Measurement range | 40 mm | 9999 mm | Resolution of 1mm |
RF Module Specifications
Powered by a single Tadiran lithium inorganic battery, with a 3.6V (9000mAh capacity).
While changing the batteries:
- Turn off the sensor
- Only use an equivalent 3.6V battery
- Checkout the polarity marking on the battery holder and the battery
- Replace the battery
| Batteries | - | 1 | - | The devices comes with a single 9000mAh battery |
Ultrasonic Long Range Wireless Tank Level Sensor.
