- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
Introducing NCD’s Ultrasonic Long Range Wireless Tank Level Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating a corrosion resistant Ultrasonic proximity detection sensor, this wireless device transmits highly accurate tank levels as distance values at user-defined intervals. The Ultrasonic tank level sensor features 1mm resolution with a distance measurement range of 40 to 9999mm. Please note the recommended useful range is 500 to 9999mm for best reliability. The Ultrasonic tank level sensor is IP67 rated and comes with a 75 inch (1.9 Meter) probe while the transmitter has a IP65 rating.
Applications requiring 100% reading-to-reading reliability should not use Ultrasonic Tank Level Sensors at a distance closer than 500mm. Although many users have found a Ultrasonic Tank Level Sensor to work reliably from 0 to 50cm for detecting objects, it is not guaranteed to have operational reliability for objects closer than the minimum reported distance. Because of ultrasonic physics, these sensors are unable to achieve 100% reliability at close distances.
- Industrial Grade Ultrasonic Tank Level Sensor
- Reading-to-Reading stability of 1mm at 1 Meter (typical)
- 500 to 9999mm Measurement Range with 1mm Resolution
- 40 to 499mm Measurement Range with Reduced Reliability
- Target Size Compensation for Greater Consistency and Accuracy
- Fully Calibrated and Linearized with Temperature Compensation
- Long Range Wireless Range of Up to 2 Miles Line of Sight
- 128-Bit AES Encrypted Wireless Communications
- Standard Electrical 3/4 Inch PVC Pipe Fitting
- Supports Smart Percentage Detection Change Mode
- Validates and Retries on Lost Communication Packets
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
- Configuration Button Pressed and held immediately after reset for- < 2 second – device starts normally in RUN Mode
Default Configuration
| Network ID | 7F FF (HEX) |
| Node ID | 0 |
| Delay | 600 (DEC) seconds |
| Power | +24 dBm |
| Retries | 10 |
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID- A user configurable parameter allowing a user to input a simple id for a particular sensor
- firmware- This identifies the firmware version of the sensor sending the packet
- battery- The current voltage level of the batteries at the time of transmission
- battery_percent- The current battery percent at the time of transmission
- counter- The number of transmissions since boot or counter rollover
- sensor_type- The machine identifiable type of the sensor
- sensor_data- Object containing all sensor data related to this sensor
- sensor_name- Human Readable Sensor Type Identifier
- type- An easily passed message type declaration
- addr- The unique identifier of the sensor that transmitted the data
- received- Epoch indicator of when the data was received by Node-Red
- original- Auxiliary information on the packet and underlying protocol
- modem_mac- The unique identifier of the Gateway/Modem that received the data
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 34,
    "sensor_data": {
         "level": 5
    "sensor_name": "Tank Level Sensor",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
- level- This is the distance measured from the sensor to the surface of the liquid in the tank in mm.
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 34,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
		Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
  "payload": {
    "type": 34,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
		Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
  "payload": {
    "type": 34,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
		Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
  "payload": {
    "type": 34,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
		Wireless Gateway FLY Message
- topic- Indicates the type of message this is
- payload- Contains the primary data of the message
- payload.mac- Indicates the unique address of the sensor sending the mode message
- payload.type- Indicates the type of sensor sending the mode message
- payload.nodeId- A user configurable parameter allowing a user to input a simple id for a particular sensor
- payload.mode- indicates the current mode of the sensor
- payload.lastHeard- Timestamp of the message
  "payload": {
    "type": 34,
    "nodeId": 0,
    "mode": "FLY",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
															Wireless Device No Mode
															Wireless Device FLY Mode
															Wireless Device Config Mode
															Wireless Device Node Messages
- data- Contains the sensor data and all other pertinent details of the sensor
- data.nodeID- A user configurable parameter allowing a user to input a simple id for a particular sensor
- data.firmware- This identifies the firmware version of the sensor sending the packet
- data.battery- The current voltage level of the batteries at the time of transmission
- data.battery_percentage- The current battery percent at the time of transmission
- data.counter- The number of transmissions since boot or counter rollover
- data.sensor_type- The machine identifiable type of the sensor
- data.sensor_data- Object containing all sensor data related to this sensor
- data.sensor_name- Human Readable Sensor Type Identifier
- data.type- An easily passed message type declaration
- data.addr- The unique identifier of the sensor that transmitted the data
- data.received- Timestamp of the message
- data.original- Auxiliary information on the packet and underlying protocol
- data.modem_mac- The unique identifier of the Gateway/Modem that received the data
- payload- Object containing all sensor data related to this sensor
- time- Timestamp of the message
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 34,
    "sensor_data": {
         "level": 100
    "original": {...},
    "modem_mac": ""
  "payload": {
         "level": 100
  "_msgid": "48e99332fc104565"
- topic
- payload
- payload.x
- time
- addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
- topic
- time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
- Name- Arbitrary name of this node
- Serial Device*- The primary communication interface used to receive data from the sensor
- Serial Device for Config- A secondary communication interface used to configure sensors without losing sensor data
- Mac Address- Using this field allows you to choose a specific sensor that corresponds to this Wireless Device node
- Sensor Type*- This field limits the sensors that correspond to this Wireless Device node to a particular type of sensor
- Auto Config- Checking the box next to this field tells Node-Red that the sensor(s) corresponding to this Wireless Device node should be configured when put into Configuration Mode manually
*Required
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
											TCP Socket Connection
- Name- This allows you to enter a human readable name for identifying this config node
- Modem Type- This allows you to choose between USB (Serial) or TCP (Ethernet/Network)
- TCP Port- Select the TCP Port that the modem is listening on
- IP Address- The IP address of the Ethernet Modem on the network
- Network ID- Network IDs allow you to have multiple groups of sensors, repeaters, and Gateway/Modems in a single area without interfering with each other
- Add RSSI to incoming packets- Selecting this box will add a signal strength indicator to all incoming comms
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor- Press and release the RESET button and then immediately hold the CFG button for > 15 seconds
- You should receive a sensor_mode message with the mode of PUM and then a second sensor_mode message with the mode of PGM- It is recommended to have a Debug node connected directly to the Wireless Gateway node to see these messages
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 34 – Wireless Tank Level
- Click on Import
Example Flows
