- A Machine Uptime Monitoring Sensor
Enterprise Gateway Setup
- 1 x Enterprise Gateway
- 2 x WiFi Antennas
- 1 x Digimesh Antenna
- 1 x Din Rail Adapter
- 1 x Power Supply
- 1 x Two Position Terminal
- 1 x Three Position Terminal
- 1 x Eight Position Terminal
- Attach any probes you will use- Use the Machine Uptime Monitor Datasheet for reference on where and how to attach the probes
- Turn on the sensor- If using battery power set the power switch to ON BAT
- Press the CFG Button to check for power- If the TEST LED lights up while the CFG button is held down the sensor is powered
Software Setup
- Connect your computer to the WiFi Network of the Enterprise Gateway- The Network will be name NCD_Edge_xxxx where xxxx is the last four characters of the MAC address printed on the side of the gateway
- Open a web browser and in the URL bar enter 192.168.0.1:1880 to bring up Node-Red- You can also use the .local address: ncd-xxxx.local:1880 where xxxx is the last four characters of the MAC address printed on the side of the gateway
Final Steps
