- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
The Machine Uptime Monitor is a device specifically designed to track machine and production uptime in industrial settings. It is a flexible device that can be configure to observe one or more events via different input types – accelerometer, magnetometer, current sensor, break beam sensor, photo eye sensor, reflector sensor, current sensor.
It has long range wireless capabilities utilizing robust Mesh networking protocols with high level of security and network reliability. It is compact, durable and powered by long lasting batteries.
- Industrial Grade Machine Uptime Monitoring
- Measure Production Uptime
- Measure Number of Cycles
- Dry Contact Closure Input
- Wet Contact Closure Input
- Acceleration Motion Detection based Uptime calculator
- Magnetic Field Detection based Uptime calculator
- Current-based Uptime calculator
- Wall-Mounted or Magnet Mounted IP65
- Rated Enclosure
- For Indoor and Outdoor Use
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 108,
"sensor_data": {
"digital_input_counter": 0,
"digital_input_uptime": 0,
"ct_input_counter": 0,
"ct_input_uptime": 0,
"opto_input_counter": 0,
"opto_input_uptime": 0,
"accelerometer_counter": 0,
"accelerometer_uptime": 0,
"magnetometer_counter": 0,
"magnetometer_uptime": 0
"sensor_name": "Machine Uptime Monitoring Sensor",
"type": "sensor_data",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
- digital_input_counter
- The number of counters on the digital input since last reset
- digital_input_uptime
- The uptime detected by the digital input since last reset in seconds
- ct_input_counter
- The number of times the Current Transducer detected activity since last reset
- ct_input_uptime
- The amount of time the Current Transducer detected activity since last reset in seconds
- opto_input_counter
- The number of detections on the optical input since last reset
- opto_input_uptime
- The amount of time the Optical Input detected activity since last reset in seconds
- accelerometer_counter
- The number of detections on the accelerometer since last reset
- accelerometer_uptime
- The amount of time the Accelerometer detected activity since last reset in seconds
- magnetometer_counter
- The number of detections on the magnetometer since last reset
- The amount of time the Magnetometer detected activity since last reset in seconds
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"payload": {
"nodeId": 0,
"firmware": 5,
"battery": "3.28",
"counter": 26,
"sensor_type": 108,
"sensor_data": {
"magnetometer_uptime": 0,
"input_di": 0,
"input_ct": 0,
"input_opto": 0,
"input_acc": 0,
"input_mag": 0,
"report_type": "Regular",
"rtc": "09:18:03"
"original": {...},
- ct_input_counter
- ct_input_uptime
- opto_input_uptime
- input_di
- The current logical status of Digital Input 1 (HIGH/LOW)
- input_ct
- The current logical status of CT Probe (HIGH/LOW)
- input_opto
- The current logical status of Opto Input (HIGH/LOW)
- input_acc
- The current logical status of Acceleration Input (HIGH/LOW)
- input_mag
- The current logical status of Magnetometer Input (HIGH/LOW)
- report_type
- Indicates the reason for the sensor’s data transmission.
“Regular“: Data transmission occurred at the configured Data Transmission Interval.
“Shift End“: Data transmission was triggered by an automatic reset event (either a Reset Timeout or a configured Shift Time Reset).
“Interrupt“: Data transmission was triggered immediately by a detected signal change on a specified input (Push Notification).
“Threshold“: Data transmission was triggered because a counter value on any input reached its configured Counter Threshold.
- rtc
- Reports the sensor’s internal Real-Time Clock (RTC) in HH:MM:ss format.
(e.g., “09:18:03”)
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 108,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 108,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 108,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 108,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 108,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 108,
"sensor_data": {
"original": {...},
"payload": {
"_msgid": "48e99332fc104565"
- ct_input_counter
- ct_input_uptime
- opto_input_uptime
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 5,
"battery": "3.28",
"counter": 26,
"sensor_type": 108,
"sensor_data": {
"input_di": 0,
"input_ct": 0,
"input_opto": 0,
"input_acc": 0,
"input_mag": 0,
"rtc": "09:18:03"
"original": {...},
"payload": {
"nodeId": 0,
"firmware": 5,
"battery": "3.28",
"counter": 26,
"sensor_type": 108,
"sensor_data": {
"input_di": 0,
"input_ct": 0,
"input_opto": 0,
"input_acc": 0,
"input_mag": 0,
"rtc": "09:18:03"
- ct_input_counter
- ct_input_uptime
- opto_input_uptime
- input_di
- input_ct
- input_opto
- input_acc
- input_mag
- report_type
- rtc
(e.g., “09:18:03”)
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
- OTF Config
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Set Accelerometer Threshold
Sets the threshold in multiples of 32mg in which an uptime will be detected. A value of 1 = 32mg, a value of 2 = 64mg etc. This is what determines if you properly measure you uptime cycle while using the accelerometer probe, make sure you adjust it based on the vibration you expect your machine to produce while active.
Set Input Debounce Time
Sets the debounce time in milliseconds on inputs. State changes to the input during this debounce time will be ignored. Generally recommended for mechanically triggered state changes such as button or relay/contactor outputs. This settings will apply to the Dry Contact, Wet Contact/Optical Sensor, and the Current Transducer.
Set Contact Closure Detection
Configures how the counter increments and how uptime is calculated for Contact Closure Input:
Rising Edge: The counter increments, and uptime is calculated, when the input transitions from LOW to HIGH (active HIGH).
Falling Edge: The counter increments, and uptime is calculated, when the input transitions from HIGH to LOW (active LOW)
Set Current Transducer Detection
Configures how the counter increments and how uptime is calculated for Current Transducer Input:
Falling Edge: The counter increments, and uptime is calculated, when the input transitions from HIGH to LOW (active LOW).
Set Wet Contact/Optical Sensor Detection
Configures how the counter increments and how uptime is calculated for Contact/Optical Input:
Set Interrupt Timeout
Set the sensor to detect an initial IO (input/output) change and not transmit subsequent IO changes for a specified duration; set the duration value to control how long changes are ignored in milliseconds, set it to 0 to disable ignoring.
**Only applies to sensors with firmware version 11 and above.
Valid range: 0 – 65000 milliseconds.
Default value: 0 ms (Disabled)
Enable Quality of Service
This setting only functions when a Destination Address is also configured into the sensor.
If QoS is enabled the sensor will wait for a receipt acknowledgement from the intended receiver before resuming sleep.
If no receipt acknowledgement is received the sensor will one more time to transmit the data.
Default Configurations
| Network ID | 7F FF (HEX) |
| Node ID | 0 |
| Delay | 600 (DEC) seconds |
| Power | +24 dBm |
| Retries | 10 |
| Enable Accelerometer Error Reporting | Disabled |
| Set Accelerometer Threshold | 10 |
| Set Input Debounce Time | 10 |
| Set Contact Closure Detection | Rising Edge Trigger |
| Set Current Transducer Detection | Rising Edge Trigger |
| Set Wet Contact/Optical Sensor Detection | Falling Edge Trigger |
| Counter Threshold | 1000 |
| Enable Push Notification | Disable All |
| Enable Accelerometer | Enabled |
| Data Transmission Interval | 15 minutes |
| Reset Timeout | 60 |
| Set Shift Time 1 | 0, 0 |
| Set Shift Time 2 | 0, 0 |
| Set Shift Time 3 | 0, 0 |
| Set Shift Time 4 | 0, 0 |
| Set Reset Mode | Do not reset counters |
| Enable Quality of Service | Disabled |
| Set RTC | Disabled |
| Set Fly Interval | 1 Hour |
| Set Accelerometer Sample Rate | 10 Hz |
| Set Interrupt Timeout | 0 ms |
| Set Screen On Time | 5 seconds |
| Set Screen Control | IO1 |
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
We have built an example dashboard to display the sensor data from a single Machine Uptime Monitor. You can find it by importing it directly into Node-Red.
- Import
- Expand Type 108 – Machine Uptime Monitoring Sensor
- Click on Import
Example Flows
