LabVIEW Relay Controller Advanced Configuration
In this LabVIEW Relay Controller Advanced Configuration guide we will learn how to set relay delay, read delay, set, read relay bank values and relay test bench.
A) Set and Read Character Delay Value
This guide illustrates how to set and read character delay value
Related Example in Driver: Character Delay Configuration.vi
VIs Required:
–> Initialize (Main Palette)
–> Set Character Delay (Configuration->Advanced Palette)
–> Read Character Delay (Configuration->AdvancedĀ Palette)
–> Close (Main Palette)
Details of steps is as under.
- Port is initialized in Initialize VI with fixed baud rate of 115200.
- Set Character Delay VI is placed. It sends the command and also verifies the returned status.
- Read Character Delay VI is placed which reads back the saved value.
- Port is closed.
- Text boxes for TX and RX data are placed and their references are passed to the Instrument VI which display the serial data sent and received by the instrument driver.
Front Panel
B) Set and Read Repetitions
This guide illustrates how to set repetitions value and read it back.
Related Example in Driver: Repetitions Configuration.vi
VIs Required:
–> Set Repetitions(Configuration->Advanced Palette)
–> Read Repetitions(Configuration->AdvancedĀ Palette)
- Set Repetitions VI is placed. It sends the command and also verifies the returned status.
- Read Repetitions VI is placed which reads back the saved value.
- Port is closed.
Front Panel
C) Set and Read Test Cycle
This guide illustrates how to set test cycle value and read it back.
Related Example in Driver: Test Cycle Configuration.vi
VIs Required:
–> Set Test Cycle (Configuration->Advanced Palette)
–> Read Test Cycle (Configuration->AdvancedĀ Palette)
- Set Test Cycle VI is placed. It sends the command and also verifies the returned status.
- Read Test Cycle VI is placed which reads back the saved value.
- Port is closed.
Front Panel
D) Set and Read Attached bank value
This guide illustrates how to set attached bank value and read it back.
Related Example in Driver: Attached Bank Value Configuration.vi
VIs Required:
–> Set Attached Bank Value (Configuration->Advanced Palette)
–> Read Attached Bank Value (Configuration->AdvancedĀ Palette)
- Set Attached Bank Value VI is placed. It sends the command and also verifies the returned status.
- Read Attached Bank Value VI is placed which reads back the saved value.
- Port is closed.
Front Panel
To Download the Labview Relay Driver and relay controller checkout Installing Labview relay controller Driver.
