Installation Guide for Atrium Gateways
Step 1. Ensure you are using a PC with internet access that is on the same network as the Atrium Gateway (or connected directly to the gateway via an Ethernet cable).
Step 2. Open PowerShell or Command Prompt from your computer’s Start menu.
Step 3. In your terminal, type the following command, replacing `XXXX` with the last four digits of your gateway’s MAC address, and press Enter:
ssh ncdio@ncd-XXXX.local
Example: ssh ncdio@ncd-7f53.local
Step 4. You will be prompted to enter a password. Unless you have previously changed it, type the default password below and press Enter:
ncdB3ast
Step 5. In the terminal, type the following command and press Enter:
cd .node-red/
Step 6. To install the update from the temp-dev branch, type the following command exactly as shown and press Enter:
npm install https://github.com/ncd-io/node-red-enterprise-sensors/tree/temp-dev
Step 7. Once the installation finishes, type the following command and press Enter to restart the services and apply your changes:
pm2 restart all
Step 8. Close the terminal window. You can now access your Atrium Interface again with the newly applied updates.
Installation via Node-RED for Enterprise IIoT Gateway
- Industrial IoT Gateway: An NCD Enterprise-series gateway.
- Node-RED Access: Access to the Node-RED flow editor.
- Network Connectivity: Active internet access for the gateway (required for library installation).
Procedure
Step 1. Go to ‘update ncd library‘ github repo and click on the copy raw file button:
Step 2. Access the Node-RED editor on your NCD Gateway. Navigate to the Menu (the three horizontal lines in the top-right corner) and select the ‘Import’ option:
Step 3. Paste the JSON code into the text input field within the Import dialog, then click the ‘Import’ button to proceed:
Step 4. Go to the new ‘Update library’ tab on your Node-RED workspace:
Step 5. Click on the ‘Deploy’ button located at the top right side:
Step 6. Trigger the first flow by clicking the embedded left button, as shown in the following image:
Step 7. A few seconds after enabling the flow, you should see the ‘pid’ process and then the “Completed” message under the debug node, as shown in the following image:
Step 8. Enable the second flow by clicking the embedded left button, as shown in the following image:
This flow enables a command to restart Node-RED on the Gateway.
Step 9. Finally refresh the web browser page. It will take a few minutes to restart Node-RED.
After completing these steps, your NCD Library has been updated from the temp-dev branch.
Offline Installation via SCP
Must-have
- Enable SSH: SSH into your IoT Enterprise Gateway
Step 1: Using a PC with internet access that is also on the same network as the NCD Gateway (or connected via Ethernet), navigate to the NCD GitHub Library repository and switch to the temp-dev branch. Click the green ‘Code‘ button and select ‘Download ZIP‘ from the dropdown menu to save the library locally.
Step 2: Extract the contents of the ZIP file.
Step 3: Rename the extracted folder to exactly: node-red-enterprise-sensors
Step 4: Type cmd into the Windows Explorer Address Bar and press Enter to open a Command Prompt window within the current directory.
Step 5: Enter the following command to copy and replace the node-red-enterprise-sensors folder in the Gateway’s Node-RED directory. Replace xxxx with the last four digits of your Gateway’s MAC address (found on the nameplate located on the bottom of the unit):
scp -r node-red-enterprise-sensors ncdio@ncd-xxxx.local:/home/ncdio/
Step 6: You will be prompted for the Gateway password. The default password is:
ncdB3ast
Step 7: SSH to the Gateway:
ssh ncdio@ncd-xxxx.local
Step 8: Use these commands to install the library:
cd ~/.node-red
npm install /home/ncdio/node-red-enterprise-sensors
Step 9: Once the process is complete, you may reboot Node-RED process, use this command:
pm2 restart all
