Introducing NCD’s IoT Industrial Wireless Absolute & Gauge Pressure and Temperature Sensor is the OEM piezo resistive pressure sensor with 316L stainless steel corrugated diaphragm and isolated oil-filling construction, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating a highly accurate Absolute & Gauge pressure sensor, transmits data at user-defined intervals. It measures Absolute & Gauge pressure and temperature with user configurable resolution at user defined intervals while sleeping during the time when it is not measuring or sending data.
Industrial Wireless Absolute & Gauge Pressure and Temperature Sensor is widely used for various liquid pressure measurement which is compatible with stainless steel and Viton®. The included sensor is rated for 0-100psi absolute pressure, 0-500psi gauge pressure sensor, 0-1000psi sealed gauge sensor with an accuracy of ±0.5%FS (pressure), and 0-5000psi sealed gauge sensor with an accuracy of ±0.5%FS (pressure)  ±1.5℃ (Temperature). Easily interfaces using a standard 1/4″ NPT Male connection.
- Industrial Grade Sensor Long Range Wireless Pressure Temperature Sensor
- Operating Range 0 to 10,000psi, -40°C to +85°C (-40°F to 185°F)
- Industry Standard 1/4 inch NPT Male Connector
- Accuracy ±0.5%FS (pressure)  ±1.5℃ (Temperature)
- Sampling Frequency 1.5ms
- Long Term Stability: ±0.3%FS/year
- Compatible Media – Gas, Liquid or Vapor
- Node-RED compatible – for configuration and displaying of data (NCD provided libraries)
- IP65 Rated Enclosure
- Improved reliability incorporating Retry feature in case of packet loss
- Real Time Battery Status
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Probe Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Pressure range in PSI | 0 | 10 000 | Depending on the chosen probe when purchasing you range might be lower, we are listing the max here |
RF Module Specifications
- External power supply (5-12 V DC) Current Requirement 250 mA
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 6 TPD | 10 Years | TPD Transmissions per Day | ||
| Battery Life 24 TPD | 6 Year | TPD Transmissions per Day | ||
| Battery Life 96 TPD | 4 Year | TPD Transmissions per Day |
Head to the NCD store if you want to purchase the Absolute & Gauge Pressure Sensor.
