Industrial Wireless Absolute & Gauge Pressure Sensor With 1/4 NPT User Manual
Introducing NCD’s IoT Industrial Wireless Absolute & Gauge Pressure and Temperature Sensor is the OEM piezo resistive pressure sensor with 316L stainless steel corrugated diaphragm and isolated oil-filling construction, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating a highly accurate Absolute & Gauge pressure sensor, transmits data at user-defined intervals. It measures Absolute & Gauge pressure and temperature with user configurable resolution at user defined intervals while sleeping during the time when it is not measuring or sending data.
Industrial Wireless Absolute & Gauge Pressure and Temperature Sensor is widely used for various liquid pressure measurement which is compatible with stainless steel and Viton®.  The included sensor is rated for 0-100psi absolute pressure, 0-500psi gauge pressure sensor, 0-1000psi sealed gauge sensor with an accuracy of ±0.5%FS (pressure),  and 0-5000psi sealed gauge sensor with an accuracy of ±0.5%FS (pressure)  ±1.5℃ (Temperature).  Easily interfaces using a standard 1/4″ NPT Male connection.
  • Industrial Grade Sensor Long Range Wireless Pressure Temperature Sensor
  • Operating Range 0 to 10,000psi, -40°C to +85°C (-40°F to 185°F)
  • Industry Standard 1/4 inch NPT Male Connector
  • Accuracy ±0.5%FS (pressure)  ±1.5℃ (Temperature)
  • Long Term Stability: ±0.3%FS/year
  • Compatible Media – Gas, Liquid or Vapor
  • Node-RED compatible – for configuration and displaying of data (NCD provided libraries)
  • IP65 Rated Enclosure
  • Improved reliability incorporating Retry feature in case of packet loss
  • Real Time Battery Status
Hardware Controls
Power Switch
  • Battery Power
  • External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
  • Configuration Button Pressed and held immediately after reset for
    • < 2 second – device starts normally in RUN Mode
    • 2 to 15 seconds – device goes into Configuration Mode
Click to enlarge
Wireless Gateway Nodes
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 26,
    "sensor_data": {
      "pressure": 500,
      "temperature": 60,
    "sensor_name": "Pressure &amp; Temperature Sensor (PSI)",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
  • pressure
    •  The measured pressure in PSI
  • temperature
    •  The measured temperature in Celsius
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
    • Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 26,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 26,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 26,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 26,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 26,
    "nodeId": 0,
    "mode": "FLY",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
  • topic
  • payload
  • time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
Click to enlarge
Wireless Device Nodes
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 26,
    "sensor_data": {
      "pressure": 500,
      "temperature": 60,
    "original": {...},
  "payload": {
      "pressure": 500,
      "temperature": 60,
  "_msgid": "48e99332fc104565"
msg.payload Breakdown
  • pressure
  • temperature
  • topic
  • payload
  • payload.x
  • time
  • addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
  • topic
  • time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes​
  • Serial Device for Config
  • Mac Address
  • Sensor Type*
  • Auto Config
  • OTF Config
    • Checking the box next to this field AND having Auto Config checked tells Node-Red that the sensor(s) corresponding to this Wireless Device node should be configured when a FLY message is detected
*Required
General Sensor Configurations
  • Wait for Network Formation
  • Destination Address
  • Network ID
  • Node ID and Delay
    • Node ID
    • Delay
  • Power
  • Retries
Default Configurations
ParametersDefault Value
Destination Address00 00 FF FF (HEX)
Network ID7F FF (HEX)
Node ID0
Delay600 (DEC) seconds
Power+24 dBm
Retries10
Serial Connection
  1. Name
  2. Modem Type
  3. Serial Port
  4. Baud Rate
  5. Network ID
    • The default value is 7FFF
TCP Socket Connection
  1. Name
  2. Modem Type
  3. TCP Port
  4. IP Address
  5. Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Press and release the RESET button and then immediately hold the CFG button for > 15 seconds
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
We have built an example dashboard to display the sensor data. You can find it by importing it directly into Node-Red.
  2. Import
  5. Expand Type 26 – Pressure & Temperature (PSI)
  8. Click on Import
Example Flows
