NCD.io › Documentation › Industrial IoT Wireless RTD Temperature Sensor
Atrium · RTD Temperature
Industrial-grade wireless temperature monitoring for a single RTD probe, with Atrium IIoT Gateway integration. Accepts any 100 Ω 3-wire PT100 probe (PT1000 selectable) via its M12 8-pin connector, reads it with a 15-bit ADC for ±0.5°C full-scale accuracy, and transmits over its long-range wireless mesh. SKU PR55-44.
Buy Now →
Sensor Type
RTD Temperature (Atrium type 39)
Last updated
2026-07-29
01Overview
The NCD Industrial IoT Wireless RTD Temperature Sensor is a battery-powered wireless transmitter that reads a single RTD temperature probe and reports it to an Atrium IIoT Gateway at user-defined intervals over its long-range wireless mesh network. The channel accepts a standard 100 Ω 3-wire PT100 probe (PT1000 selectable) connected via its M12 8-pin connector, and a 15-bit ADC delivers ±0.5°C full-scale accuracy with 0.03125°C nominal resolution. A sample PT100 probe is included for bench testing. The sensor ships configured for the frequency band and power option selected at time of order.
Video walkthrough — overview and Atrium setup of the Industrial IoT Wireless RTD Temperature Sensor.
The sensor ships with one of three wireless communication modules. Choose the frequency band that matches your gateway and region — the sensor core, firmware, and Atrium integration are identical across all three. The 900 MHz and 868 MHz options run on NCD’s sub-GHz wireless mesh network, which cuts through industrial noise and interference for secure, long-range communication.
Wireless ModuleRegionLine-of-Sight RangeIndoor / Urban Range
900 MHzNorth & South America~2 miles~1,000 ft
868 MHzEurope~2 miles~1,000 ft
2.4 GHzWorldwide~1 mile~300 ft
±0.5°C RTD Accuracy
A single 3-wire PT100 RTD input (PT1000 selectable) read by a 15-bit ADC, delivering ±0.5°C full-scale accuracy and 0.03125°C nominal resolution.
Long-Range Wireless
Up to ~2 miles line-of-sight with the on-board antenna (~1,000 ft in urban environments) over a secure 128-bit AES long-range wireless mesh — 900 MHz, 868 MHz, or 2.4 GHz.
Battery or External Power
D-cell (LR20) lithium battery with integrated supercapacitor — up to 5 years; estimate for your configuration with NCD’s battery life calculator. Run on battery or an external power supply — both supported.
Rugged Industrial Enclosure
IP65 / NEMA 1, 2, 4, 4X, 12, 13 / UL-508 industrial enclosure with 1/4 NPT, 1/4-28 UNF, and magnet-mount options.
What’s in the Box
  • Industrial IoT Wireless RTD Temperature transmitter (main unit) with on-board antenna
  • Wireless communication module per your selection (900 MHz, 868 MHz, or 2.4 GHz) with antenna
  • One sample 100 Ω 3-wire PT100 probe with PG9 connector (for bench testing only — see note below)
  • D-cell (LR20) lithium battery with integrated supercapacitor (power switch ships in the OFF position)
  • Mounting hardware
02Specifications
Full technical specifications for the Industrial IoT Wireless RTD Temperature Sensor (SKU PR55-44). The temperature range listed below is for the sensor electronics — the usable measurement range at the probe tip depends on the PT100 probe you fit.
ParameterSpecification
Channels1 RTD input
Probe Type100 Ω 3-wire PT100 (PT1000 selectable; custom probes available)
RTD Input3-wire PT100 RTD, via M12 8-pin connector
ADC Resolution15-bit
Temperature Resolution0.03125°C nominal with default PT100 probe (varies with RTD nonlinearity)
Accuracy±0.5°C full scale
Measurement Range (probe)Depends on the PT100 probe fitted — observe the probe’s own rated range
Enclosure Operating Temp (electronics)−40°C to 85°C
Enclosure RatingIP65; NEMA 1, 2, 4, 4X, 12, 13; UL-508
Enclosure Dimensions3.54″ W × 4.52″ L × 2.16″ H
Mounting1/4 NPT, 1/4-28 UNF, or magnet mount
Wireless ModuleSelect 900 MHz (North & South America), 868 MHz (Europe), or 2.4 GHz (worldwide) at time of order
Line-of-Sight Range~2 miles (900/868 MHz); ~1 mile (2.4 GHz); ~1,000 ft urban
AntennaOn-board antenna
Transmitter PowerUp to +24 dBm
Data Rate200 Kbps
Encryption128-bit AES
Power SupplyBattery (D-cell LR20 lithium with supercapacitor) or external power supply — both supported
Battery LifeUp to 5 years — varies with configuration. Estimate for your settings with the battery life calculator
Default Transmission Interval600 seconds (10 minutes), configurable
SKUPR55-44
03Prerequisites
Before installing this sensor, make sure you have the following in place.
Hardware Required
  • NCD Atrium IIoT Gateway — powered on and connected to your local network
  • Industrial IoT Wireless RTD Temperature Sensor (this unit)
  • A 100 Ω 3-wire PT100 probe rated for your application (the included sample probe is for bench testing only)
  • D-cell (LR20) lithium battery (included, switch in the OFF position for shipping) — or the external-power option if ordered
Software / Network
  • A current version of Atrium running on your gateway
  • A computer or mobile device on the same local network as the gateway
  • A modern web browser (Chrome recommended)
  • A gateway configured for the same wireless frequency band as this sensor (900 MHz, 868 MHz, or 2.4 GHz)
04Mounting & Installation
Connect the RTD probe first, then power on and mount the enclosure. The enclosure supports 1/4 NPT, 1/4-28 UNF, and magnet mounting.
Connecting the RTD Probe
The sensor enclosure carries an M12 8-pin connector. A 3-wire PT100 RTD probe is supplied with the sensor, terminated with a PG9 connector that connects to that port — align the connector, push it on, and hand-tighten the coupling until snug so it cannot work loose under vibration. If you are measuring with a PT1000 probe, set the RTD Range accordingly in Hardware Settings (see Section 8).
rtd probe
The 3-wire PT100 RTD probe supplied with the sensor — stainless tip, braided cable, and a PG9 connector that plugs into the sensor’s M12 8-pin port.
To wire your own probe, terminate its three leads into the PG9 connector assembly (below) following the M12 pinout — the connector consists of a gland nut, a sealing insert, the body, and a terminal block where the leads are screwed down.
pg9 exploded view
PG9 connector assembly — gland nut, sealing insert, body, and terminal block. Land the probe leads on the terminal block per the pinout, then reassemble.
M12 PinWire ColorFunction
1RedRTD IN−
2RedCOMP / SENSE
3ClearRTD IN+
4–8—No connection
Powering On
  1. 1
    Open the enclosure
    Remove the screws securing the enclosure lid and lift the cover to expose the PCB, battery, and power switch.
  2. 2
    Set the power switch
    The power switch has three positions: Battery Power, Off, and External Power. It ships in the Off position. Move it to Battery Power for battery operation, or External Power if you ordered the external-power option and have it connected.
  3. 3
    Verify power
    Press the CFG button — the on-board TEST LED illuminates to confirm power is present. There is no continuously lit power LED; this is intentional to conserve battery. Press RESET to start the sensor; it sends two data packets on start-up to confirm operation.
  4. 4
    Close and seal the enclosure
    Route the probe cable through the enclosure gland, replace the lid, and tighten the screws evenly to maintain the IP65 seal.
01 sensor enclosure open
Sensor enclosure open showing the M12 8-pin RTD connector, battery, power switch, and RESET / CFG buttons.
Mounting the Enclosure
  • Threaded mount: Use the 1/4 NPT or 1/4-28 UNF fitting to mount the enclosure to a compatible boss or bracket.
  • Magnet mount: Attach the magnetic mounting plate to any flat ferrous surface — ideal for equipment frames, panels, and pipes.
05Pairing with Atrium
Once powered on, the sensor transmits over its long-range wireless mesh and the gateway begins hearing it. New sensors are held pending (blacklisted) until you whitelist them through the Sensor Details wizard — data is not logged until a sensor is whitelisted. No radio pairing or pre-registration is required.
  1. 1
    Power on and close the enclosure
    Set the power switch to Battery Power (or External Power), press RESET, then close the lid. Within one transmission interval (up to 10 minutes at the default 600-second Delay), the gateway will begin receiving its transmissions.
  2. 2
    Open Atrium and go to Sensors
    Navigate to your gateway’s local address (e.g. http://ncd-[last-4-of-MAC].local) and click Sensors in the top navigation. A banner shows “X sensors need setup” with detected sensors grouped by type. Your unit appears under the RTD Temperature sensor type.
  3. 3
    Open the Sensor Details wizard
    Click the sensor in the banner (or in the Sensors table) to open the Sensor Details wizard. New sensors start pending (blacklisted) — completing the wizard whitelists the sensor so Atrium begins logging its data.
  4. 4
    Enter details and save
    Give the sensor a Sensor Name, Asset, and Location (see Section 6). Use Save to whitelist and finish, Save & Next to move to the next pending sensor, or Skip to leave a sensor pending for now.
  5. 5
    Confirm it is reporting
    The whitelisted sensor now appears in the Sensors table with a recent Last Heard timestamp. Open its Dashboard to confirm live temperature data.
02 sensors needs setup
Atrium detects new sensors automatically and lists them in the “sensors need setup” banner, grouped by type.
03 setup wizard sensors
The Sensor Details wizard — complete it to whitelist the sensor. Use Save, Save & Next, or Skip.
06Sensor Meta
The Sensor Meta tab controls how Atrium identifies and tracks this sensor. Access it via Sensors → [your sensor] → Configure → Sensor Meta.
FieldDescription
Sensor StatusWhitelisted — data is logged and displayed. Blacklisted — data is ignored. New sensors are blacklisted (pending) until whitelisted via the Sensor Details wizard.
Sensor NameHuman-readable label shown throughout the Atrium interface (e.g. “Chiller Loop — Supply”).
AssetThe asset or equipment this sensor is monitoring (e.g. “Chiller Loop A”).
LocationPhysical location of the sensor (e.g. “Building A — Mechanical Room”).
Report Interval (seconds)Must match the Delay value in Sensor Hardware Settings. Atrium marks the sensor offline if no data is received within 2× this value.
Install DateOptional. Records when the sensor was deployed.
Offline AlertWhen enabled, Atrium sends an email notification if the sensor stops reporting. Requires email configured in Settings → Gateway Configuration.
07Metric Configuration
The Metrics tab lets you configure conversion formulas, units, custom labels, and dashboard visibility for each data channel. Access it via Configure → Metrics.
This sensor exposes the following metrics:
MetricUnitDescription
temperature°C or °FTemperature read from the RTD probe (display unit set globally — see Section 9)
data_valid—Fault flag — indicates whether the RTD probe read correctly. A fault usually means the probe is disconnected or miswired
battery_pct%Estimated remaining battery capacity
battery_vVBattery voltage (separate from battery_pct)
rssidBmReceived signal strength — reported as a positive magnitude; higher values mean a weaker signal
counter—Transmission counter; increments each transmission — useful for detecting missed packets
Custom Conversion Formulas
Each metric supports a custom conversion formula using value as the variable name. Leave the formula as value or blank to display raw data. Examples:
Formula examples
value + 0.5            // Apply a calibration offset to the channel
value * 9/5 + 32       // Convert degrees C to F manually (prefer the global unit setting)
value * 0.01           // Scale a raw integer to a decimal
Custom Labels & Visibility
Each metric can be assigned a Custom Label that replaces the default metric name throughout Atrium (e.g. “Supply Temp”). Unchecking Visible on Dashboard hides that metric’s card and chart without deleting data.
04 metrics config
Metric Configuration — each metric exposes a conversion formula, unit, custom label, and a dashboard-visibility toggle.
08Hardware Settings
Hardware settings control the sensor’s on-board configuration — transmission interval, RTD probe type, network addressing, and node identity. Changes are staged in Atrium and pushed to the sensor on its next configuration check-in. Access via Configure → Sensor Configuration.
RTD Probe Settings
SettingDefaultDescription
Set RTD RangePT100Selects the RTD element the channel is calibrated for — PT100 or PT1000. Match this to the probe you fitted.
Set RTD Wire Type3-wireSets the RTD wiring configuration used for lead-resistance compensation. Match this to how the probe is wired to the terminals.
ADC Resolution15-bitAnalog-to-digital converter resolution — yields 0.03125°C nominal temperature resolution with the default PT100 probe.
Network & Timing Settings
Network ID7fffThe wireless network ID. Must match the gateway’s network ID for the sensor to communicate. (Configuration mode temporarily uses 7BCD.)
Destination Address0000ffffThe broadcast address the sensor transmits to. Typically left at default unless using a custom mesh topology.
Node ID0Optional human-readable node identifier within the mesh network.
Delay600Transmission interval in seconds. Lower values increase data frequency at the cost of battery life.
Adjusting the Transmission Interval
  1. 1
    Go to Sensor Configuration
    Navigate to Sensors → [your sensor] → Configure → Sensor Configuration.
  2. 2
    Update the Delay value
    Enter your desired interval in seconds. A minimum of 60 seconds is recommended. Confirm the RTD Range and Wire Type match your fitted probe while you are here.
  3. 3
    Click Save Hardware Settings
    The new values are staged and pushed to the sensor on its next configuration check-in.
  4. 4
    Update the Report Interval in Sensor Meta
    Update the Report Interval on the Sensor Meta tab to match your new Delay value so offline detection stays accurate.
Battery Life
The sensor delivers up to 5 years of battery life. Actual life depends on your configuration — transmission interval (Delay) is the biggest factor. Longer intervals extend life; frequent transmissions shorten it. To estimate battery life for your exact settings, use NCD’s battery life calculator. For high-frequency monitoring, run the sensor on an external power supply.
05 hardware settings
Sensor Configuration tab — set the RTD Wire Type and RTD Range to match your fitted probe. Network ID, Destination Address, Node ID, and Delay are set here too.
09Temperature Units
Atrium provides a global temperature display unit setting that controls how temperature readings appear across the entire interface — all sensors, dashboards, alerts, and reports, including this sensor.
  1. 1
    Open Gateway Settings
    Click Settings in the top navigation to open Gateway Configuration.
  2. 2
    Select Temperature Display Unit
    Under Temperature Display Unit, toggle between °C and °F. This applies immediately to all temperature readings across Atrium.
  3. 3
    Save Configuration
    Click Save Configuration at the bottom of the page to apply the change.
06 gateway settings temp unit
The Temperature Display Unit toggle in Gateway Settings applies to all sensors globally.
10Sensor Dashboard
The Sensor Dashboard provides a real-time and historical view of all data from this sensor. Access it by clicking the sensor in the Sensors list and selecting Dashboard.
Live Metrics
Temperature°F or °CCurrent temperature from the RTD probe
Data Valid—Fault flag confirming the RTD channel is reading correctly
Battery Pct%Estimated remaining battery capacity
RSSIdBmSignal strength as a positive magnitude — higher values mean a weaker signal
Counter—Packet counter that increments with each transmission; useful for detecting missed packets
Time Range & Charts
Use the time range selector to view historical data for the last hour, 6 hours, 24 hours, 7 days, or 30 days. A custom date/time range is also available. Each metric has its own interactive chart — drag to zoom into a time window, double-click to reset. Trend temperature over days or weeks to spot developing process issues.
07 sensor dashboard
Sensor Dashboard showing live temperature, battery, and signal metrics.
Mesh Route Map
Click View Map in the Mesh Route Map panel to visualize how this sensor’s data routes through the wireless mesh to reach the gateway. Useful for diagnosing signal path issues in multi-sensor deployments.
Interactive Preview
The panel below simulates the Atrium Sensor Dashboard for this RTD Temperature sensor. Data updates every 5 seconds to demonstrate the live monitoring experience.
11Setting Alerts
Atrium uses a Triggers & Actions model for alerting. A Trigger defines the threshold condition on a metric. An Action defines what happens when all assigned triggers fire. Navigate to Alerts in the top navigation (the page is titled Alerts & Actions) to configure.
Creating a Trigger
  1. 1
    Go to Alerts → Triggers
    Click + New Trigger to open the Create Trigger form.
  2. 2
    Configure the trigger
    Select the Device, Metric (e.g. temperature), Condition (Above or Below), and Threshold value. The Reset At column sets the value the metric must return to before the trigger can fire again — this hysteresis prevents repeated firing when the value oscillates near the threshold. Click Create Trigger.
Creating an Action
  1. 1
    Go to Alerts → Actions
    Click + New Action. Actions link one or more triggers to a response — when all assigned triggers fire simultaneously, the action executes.
  2. 2
    Assign triggers and configure the response
    Select the trigger(s) to watch and configure the response. Atrium supports email notifications and relay output actions (to drive an external relay, e.g. to signal or shut down equipment). Email must be configured in Settings → Gateway Configuration for email actions to work.
08 set alert
The Alerts & Actions page — create a Trigger to define the threshold (with a Reset At value), then an Action to define the response.
12Exporting Data
All sensor data can be exported to CSV directly from the Sensor Dashboard for use in spreadsheets, reporting tools, or other analysis software.
  1. 1
    Open the Sensor Dashboard
    Navigate to the sensor and click Dashboard.
  2. 2
    Select a time range
    Choose the time range you want to export using the selector at the top of the dashboard.
  3. 3
    Click “CSV” on the desired metric
    Each metric chart has a CSV download button. Click it to download a timestamped CSV of that metric’s data for the selected time range.
Advanced: SQL Query Export
For bulk exports or custom queries across devices and date ranges, Atrium includes a SQL Query Tool (under Apps) that runs read-only SQL directly against the gateway database and exports the results to CSV. Write a SELECT against the readings table (joined to sensor_meta to filter by sensor name), click Execute Query, then Export CSV. Preset Quick Queries (Recent Readings, Readings by Sensor Name, Total Readings, and more) give you a starting point.
13Product Notes
Reference information for ordering and accessories. See Section 2 for the full hardware specifications.
ItemDetail
SKUPR55-44
RTD ProbeAny 100 Ω 3-wire PT100 probe (PT1000 and custom probe options available). The included sample probe is for bench testing only, not production.
BatteryD-cell (LR20) lithium with integrated supercapacitor — field-replaceable
External Power OptionBarrel-connector configuration — specify at time of order. Recommended for high-frequency transmission.
Frequency Bands900 MHz (North & South America), 868 MHz (Europe), or 2.4 GHz (worldwide) — selected at purchase. The sensor and gateway must use the same band.
Receiver OptionsAtrium IIoT Gateway, Enterprise IIoT Gateway, or NCD Wireless-to-USB / Wireless-to-Ethernet modem
Recovery FilesFirmware recovery files are published on the NCD community GitHub repository
Buy Now on store.ncd.io →
14Troubleshooting
Common issues and their solutions.
Sensor not appearing in Atrium
  • Press the CFG button and confirm the TEST LED lights — if it doesn’t, check the power switch position and the battery or external supply. There is no continuously lit power LED.
  • Press RESET; the sensor sends two data packets on start-up to confirm operation.
  • Verify the sensor’s Network ID matches the gateway’s Network ID (default 7fff) and that both use the same frequency band. (Note: while in Configuration mode the sensor temporarily uses Network ID 7BCD.)
  • Move the sensor to within ~3 feet / 1 meter of the gateway and press RESET to rule out range issues.
  • Check that the Atrium gateway is powered on and connected to your network.
Sensor showing as Offline in Atrium
  • Verify the Report Interval in Sensor Meta matches the Delay in Sensor Hardware Settings (both default to 600 seconds).
  • Check the battery_pct on the last received reading — replace the battery if low.
  • Check the RSSI value — remember higher numbers mean a weaker signal. Readings consistently above 75 dBm indicate marginal signal; reposition the sensor or gateway, check the antenna, or add a repeater node.
Temperature reading seems incorrect or shows a fault
  • Check the data_valid metric — a fault usually means the RTD probe is disconnected, miswired, or open-circuit. Re-seat the M12 probe connector — make sure it is fully pushed on and the threaded coupling is hand-tight — and check the wiring against the M12 pinout in Section 4.
  • Confirm the Set RTD Range (PT100 vs PT1000) and Set RTD Wire Type in Hardware Settings match the probe you fitted.
  • Confirm the Temperature Display Unit in Gateway Settings is set to your preferred unit.
  • Verify the probe is rated for the temperature being measured; the included sample probe is for room-temperature bench use only.
  • Allow 15–30 minutes after installation for the probe to stabilize to ambient conditions.
Hardware settings not updating on sensor
  • Settings are staged and applied on the sensor’s next configuration check-in — wait one full transmission interval (up to 10 minutes at the default 600-second Delay) after saving.
  • To apply changes immediately, power-cycle the sensor with the RESET button, which opens a configuration window on boot.
  • Confirm the sensor is actively transmitting by checking the Last Heard timestamp on the dashboard.
  • Ensure only one gateway is attempting over-the-air configuration of this sensor at a time.
15Factory Reset
A factory reset restores the sensor’s wireless module to default settings. This is useful if the sensor is not being detected by a gateway, or if you are redeploying it to a new network. Reset behavior is governed by how long the CFG control is held after a RESET.
CFG hold time (after RESET)Result
Less than 2 secondsNormal Run Mode
2 to 15 secondsConfiguration Mode only (Network ID temporarily 7BCD)
More than 15 secondsFactory reset to defaults, then Configuration Mode
Option A — Magnetic Switches (no disassembly)
  1. 1
    Trigger the RESET switch
    Hold a magnet near the RESET magnetic switch, then move it away.
  2. 2
    Wait 1 second
    Allow approximately 1 second before proceeding.
  3. 3
    Hold the CFG switch for ~20 seconds
    Hold the magnet near the CFG magnetic switch for approximately 20 seconds, then move it away. The hold must exceed 15 seconds to trigger a factory reset — a shorter hold only enters Configuration Mode.
  4. 4
    Wait 3–5 seconds
    Allow 3–5 seconds for the reset to complete.
  5. 5
    Trigger the RESET switch again
    Hold the magnet near the RESET switch once more, then move it away. This returns the sensor to normal Run Mode.
Option B — Physical Buttons (requires opening enclosure)
  1. 1
    Open the enclosure
    Remove the screws and lift the lid to expose the PCB.
  2. 2
    Press and release the RESET button
    Press and release the RESET button on the PCB.
  3. 3
    Wait 1 second, then hold CFG for ~20 seconds
    Wait approximately 1 second, then press and hold the CFG button for approximately 20 seconds. The hold must exceed 15 seconds to trigger a factory reset. Release the button when done.
  4. 4
    Wait 3–5 seconds
  5. 5
    Press RESET, then close the enclosure
    Press and release the RESET button to return the sensor to normal Run Mode. Replace the lid and re-secure the screws.
