Industrial IoT Wireless RTD Temperature Sensor Quick Start Guide
  1. An Industrial IoT Wireless RTD Temperature Sensor
Enterprise Gateway Setup
  • 1 x Enterprise Gateway
  • 2 x WiFi Antennas
  • 1 x Digimesh Antenna
  • 1 x Din Rail Adapter
  • 1 x Power Supply
  • 1 x Two Position Terminal
  • 1 x Three Position Terminal
  • 1 x Eight Position Terminal
  2. Attach Antenna to the sensor’s RP-SMA connector
  3. Attach any probes you will use
  4. Open the lid of the sensor by removing the 4 screws on top
  5. Turn on the sensor
    • If using battery power set the power switch to ON BAT
    • If using external power set the power switch to ON EXT
    • See section Hardware Controls of the User Manual for more information
  6. Press the CFG Button to check for power
    • If the TEST LED lights up while the CFG button is held down the sensor is powered
    • If the TEST LED does not light check the batteries or power supply to the board
  7. Move the sensor to where it is at least 3 feet or 1 Meter from the gateway
Software Setup​
  5. Press the RESET Button on the Sensor Hardware
Final Steps
  1. Close the lid of your sensor using the 4 screws to attach the lid
