The NCD Industrial IoT Wireless RTD (Resistance Temperature Detector) Temperature Sensor is capable of measuring extreme high and low temperatures with incredible precision. This IoT RTD Temperature Sensor transmitter supports any 100 Ohm 3-Wire RTD sensor, and includes a free RTD PT100 probe for the purposes of experimentation and testing within room temperature environments, but best results are achieved when connecting a high-quality sensor that meets your application requirements. This Temperature Sensor transmitter includes a on-board RTD signal amplifier for precision measurement. This wireless IoT RTD Temperature Sensor Transmitter is ideal for industrial temperature monitoring applications supporting extreme temperature ranges, such as industrial boiler temperature measurement, liquid temperature measurement, and temperature monitoring of food storage units. The Industrial IoT Wireless RTD Temperature Sensor is designed to consume extremely low power and send data at extremely long distances of up to 2 miles line-of-light or up to 28 miles using high gain antennas.
Feature
- Industrial Long Range Wireless RTD Temperature Sensor Transmitter
- Industrial Grade with an Accuracy of ±0.5°C FS
- Works with Any PT100 100-Ohm 3-Wire Sensor
- Includes Sample PT100 Sensor for Experimentation Purposes
- 15-Bit ADC Resolution; Nominal Temperature Resolution 0.03125NC
- 3-Wire Differential VREF Inputs for Common RTD Sensors
- 2-Mile Line of Sight Range with On-Board Antenna
- IP65 Enclosure Rating
- Send RTD Data to Multiple Communication
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Temperature resolution | 0.03125NC | With the default RTD PT100 probe | ||
| Temperature accuracy | ±0.5°C FS |
RF Module Specifications
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 6 TPD | 10 Years | TPD Transmissions per Day | ||
| Battery Life 24 TPD | 6 Year | TPD Transmissions per Day | ||
| Battery Life 96 TPD | 4 Year | TPD Transmissions per Day |
Industrial IoT Wireless RTD Temperature Sensor.
