Introducing NCD’s Long Range Industrial IoT Wireless Particulate Matter Sensor for Air Quality Monitoring, featuring temperature and humidity sensors with a 2-mile wireless range. It uses SPS30 and SHT30 sensors to transmit accurate particle size, mass concentration, temperature, and humidity data at user-defined intervals.
PM2.5 and PM10 particles are small pollutants dangerous to human health, linked to conditions like asthma and cardiovascular disease. The sensor measures PM1.0, PM2.5, PM4.0, and PM10.0, cleaning itself every 256 transmissions via an internal fan.
Laser scattering technology ensures accurate particle measurements over an eight-year lifetime.
The temperature sensor operates between -25°C and 85°C, while the humidity sensor handles up to 100% RH. Powered by 6 AA batteries, it lasts up to 5 years, with optional external power.
With an open communication protocol, this sensor integrates with various systems like PCs, Raspberry Pi, Microsoft Azure, AWS, and MQTT servers. Configurable transmission settings make it versatile for diverse applications.
Its long range, accuracy, affordability, and battery life make it ideal for industrial and consumer markets.
Feature
- Industrial Grade Sensor Mass Concentration Range 0-1000 μg/m³
- Mass Concentration Resolution of 1 μg/m³
- Mass Concentration Size Range PM1.0, PM2.5, PM4.0, PM10.0
- Number Concentration Range 0 to 3000 1/cm³
- Number Concentration Size Range PM0.5, PM1.0, PM2.5, PM4.0, PM10.0
- Unique Long-Term Stability of up to 8 Years
- Laser-Based Scattering Principle and Advanced Algorithms
- Inbuilt Auto Cleaning Feature After Every 256 Transmissions
- Industrial Grade Sensor with 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.04% RH/0.025°C Accuracy 2% RH/ 0.3°C
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Temperature resolution | 0.025°C | |||
| Temperature accuracy | 0.3°C | |||
| Relative Humidity range | 0 % | 100 % | ||
| Relative Humidity resolution | 0.04% | |||
| Relative Humidity accuracy | 2% | |||
| Mass Concentration range | 0 μg/m³ | 1000 μg/m³ | ||
| Mass Concentration resolution | 1 μg/m³ | |||
| Mass Concentration precision | ±10 % | |||
| Mass Concentration size range | PM1.0, PM2.5, PM4.0, PM10.0 | |||
| Number Concentration range | 0 1/cm³ | 3000 1/cm³ | ||
| Number Concentration size range | PM0.5, PM1.0, PM2.5, PM4.0, PM10.0 |
RF Module Specifications
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD | 5 Years | TPD Transmissions per Day | ||
| Battery Life 12 TPD | 2 Years | TPD Transmissions per Day | ||
| Battery Life 24 TPD | 1 Year | TPD Transmissions per Day |
Head to the NCD store if you want to purchase the Industrial IoT Wireless Particulate Matter Sensor.
