- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
Introducing NCD’s Long Range Industrial IoT Wireless Particulate Matter Sensor for Air Quality Monitoring, featuring temperature and humidity sensors with a 2-mile wireless range. It uses SPS30 and SHT30 sensors to transmit accurate particle size, mass concentration, temperature, and humidity data at user-defined intervals.
PM2.5 and PM10 particles are small pollutants dangerous to human health, linked to conditions like asthma and cardiovascular disease. The sensor measures PM1.0, PM2.5, PM4.0, and PM10.0, cleaning itself every 256 transmissions via an internal fan.
Laser scattering technology ensures accurate particle measurements over an eight-year lifetime.
The temperature sensor operates between -25°C and 85°C, while the humidity sensor handles up to 100% RH. Powered by 6 AA batteries, it lasts up to 5 years, with optional external power.
With an open communication protocol, this sensor integrates with various systems like PCs, Raspberry Pi, Microsoft Azure, AWS, and MQTT servers. Configurable transmission settings make it versatile for diverse applications.
Its long range, accuracy, affordability, and battery life make it ideal for industrial and consumer markets.
- Industrial Grade Sensor Mass Concentration Range 0-1000 μg/m^3
- Mass Concentration Resolution of 1 μg/m^3
- Mass Concentration Size Range PM1.0, PM2.5, PM4.0, PM10.0
- Number Concentration Range 0 to 3000 1/cm^3
- Number Concentration Size Range PM0.5, PM1.0, PM2.5, PM4.0, PM10.0
- Unique Long-Term Stability of up to 8 Years
- Laser-Based Scattering Principle and Advanced Algorithms
- Inbuilt Auto Cleaning Feature After Every 256 Transmissions
- Industrial Grade Sensor with 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.04% RH/0.025°C Accuracy 2% RH/ 0.3°C
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Default Configuration
| Network ID | 7F FF (HEX) |
| Node ID | 0 |
| Delay | 600 (DEC) seconds |
| Power | +24 dBm |
| Retries | 10 |
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 32,
"sensor_data": {
"mass_concentration_1_0": 5
"mass_concentration_2_5": 9
"mass_concentration_4_0": 80
"mass_concentration_10_0": 150
"number_concentration_0_5": 2
"number_concentration_1_0": 3
"number_concentration_2_5": 5
"number_concentration_4_0": 8
"number_concentration_10_0": 15
"typical_size": 10
"Humidity": 60.53
"Temperature": 25.78
"sensor_name": "Particulate Matter Sensor",
"type": "sensor_data",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
- mass_concentration_1_0
- The total mass of 1.0µm sized particles in µg/m³
- mass_concentration_2_5
- The total mass of 2.5µm sized particles in µg/m³
- mass_concentration_4_0
- The total mass of 4.0µm sized particles in µg/m³
- mass_concentration_10_0
- The total mass of 10.0µm sized particles in µg/m³
- number_concentration_0_5
- The total number of 0.5µm sized particles in #/cm³
- number_concentration_1_0
- The total number of 1.0µm sized particles in #/cm³
- number_concentration_2_5
- The total number of 2.5µm sized particles in #/cm³
- number_concentration_4_0
- The total number of 4.0µm sized particles in #/cm³
- number_concentration_10_0
- The total number of 10.0µm sized particles in #/cm³
- typical_size
- The typical particle size in µm
- Humidity
- The relative humidity in %
- Temperature
- The measured temperature in °C
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 32,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 32,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 32,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 32,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 32,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 32,
"sensor_data": {
"typical_size": 10
"Humidity": 60.53
"original": {...},
"payload": {
"typical_size": 10
"Humidity": 60.53
"_msgid": "48e99332fc104565"
- typical_size
- Humidity
- Temperature
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
- OTF Config
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 32 – Particulate Matter Sensor
- Click on Import
Example Flows
