NCD’s Long Range Industrial IoT Wireless CO2 Temperature Humidity Sensor offers air quality monitoring with an integrated temperature and humidity sensor, featuring up to a 2-mile range using wireless mesh networking. It transmits accurate CO2 concentration, temperature, and humidity data at user-defined intervals. CMOSens® technology provides precise CO2 measurements, while NDIR technology and a high-quality humidity and temperature sensor enhance accuracy.
The sensor compensates for long-term drifts using a dual-channel design, and its compact size allows easy integration. It operates from -25°C to 85°C and 0-90% RH, powered by 6 AA batteries with up to 5 years of life, depending on use. Its range, accuracy, and battery life make it a cost-effective solution for industrial and consumer applications.
Feature
- Industrial Grade CO2 Measurement Range 400 – 5’000 ppm
- CO2 Measurement Accuracy ± (60 ppm + 5% of reading)(25 °C, 400 – 5’000 ppm)
- Repeatability 10 ppm and Temperature stability
- NDIR measurement principle
- Temperature compensation of CO2 sensor signal
- Superior long-term stability With Built-in reference channel
- Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Temperature resolution | 0.025°C | |||
| Temperature accuracy | 0.3°C | |||
| Relative Humidity range | 0 % | 100 % | ||
| Relative Humidity resolution | 0.04% | |||
| Relative Humidity accuracy | 2% | |||
| CO2 Measurement range | 400 ppm | 5000 ppm | ||
| CO2 Measurement accuracy | 60 ppm + 5% of reading | |||
| Mass Concentration range | 0 μg/m³ | 1000 μg/m³ | ||
| Mass Concentration resolution | 1 μg/m³ | |||
| Mass Concentration precision | ±10 % |
RF Module Specifications
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD | 5 Years | TPD Transmissions per Day | ||
| Battery Life 12 TPD | 2 Years | TPD Transmissions per Day | ||
| Battery Life 24 TPD | 1 Year | TPD Transmissions per Day |
Industrial IoT Wireless Air Quality CO2 Temperature Humidity Particulate Matter Sensor.
