- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
NCD’s Long Range Industrial IoT Wireless CO2 Temperature Humidity Sensor offers air quality monitoring with an integrated temperature and humidity sensor, featuring up to a 2-mile range using wireless mesh networking. It transmits accurate CO2 concentration, temperature, and humidity data at user-defined intervals. CMOSens® technology provides precise CO2 measurements, while NDIR technology and a high-quality humidity and temperature sensor enhance accuracy.
The sensor compensates for long-term drifts using a dual-channel design, and its compact size allows easy integration. It operates from -25°C to 85°C and 0-90% RH, powered by 6 AA batteries with up to 5 years of life, depending on use. Its range, accuracy, and battery life make it a cost-effective solution for industrial and consumer applications.
- Industrial Grade CO2 Measurement Range 0 – 2’000 ppm
- CO2 Measurement Accuracy ± (60 ppm + + 5% of reading)(25 °C, 400 – 2’000 ppm)
- Repeatability 10 ppm and Temperature stability
- NDIR measurement principle
- Temperature compensation of CO2 sensor signal
- Superior long-term stability With Built-in reference channel
- Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Default Configuration
Parameters | Default Value |
Destination Address | 00 00 FF FF (HEX) |
Network ID | 7F FF (HEX) |
Node ID | 0 |
Delay | 600 (DEC) seconds |
Power | +24 dBm |
Retries | 10 |
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 44,
"sensor_data": {
"humidity":60.53,
"temperature":25.78
"CO2": 421
"sensor_name": "Wireless CO2 Gas Sensor",
"type": "sensor_data",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
- humidity
- The relative humidity in %
- temperature
- The measured temperature in °C
- CO2
- The CO2 value in PPM (parts per million)
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 44,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 44,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 44,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 44,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 44,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 44,
"sensor_data": {
"humidity":60.53,
"temperature":25.78
"CO2": 421
"original": {...},
"payload": {
"humidity":60.53,
"temperature":25.78
"CO2": 421
"_msgid": "48e99332fc104565"
- humidity
- temperature
- CO2
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
- OTF Config
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Advanced: Set Sensor Forced Calibration
This command will take 3 minutes to execute as the sensor calibrates. Do not reboot the sensor during this time. The configuration completed command through the UI is referring to the receipt and acknowledgement of the configuration packet.
Forced recalibration (FRC) is used to compensate for sensor drifts when a reference value of the CO2 concentration in close
proximity to the SCD30 is available. For best results, the sensor has to be run in a stable environment in continuous mode at a
measurement rate of 2s for at least two minutes before applying the FRC command and sending the reference value. Setting a
reference CO2 concentration by the method described here will always supersede corrections from the ASC.
and vice-versa. The reference CO2 concentration has to be within the range 400 ppm ≤ cref(CO2) ≤ 2000 ppm.
The FRC method imposes a permanent update of the CO2 calibration curve which persists after repowering the sensor.
Command support — Firmware version 3 or above.
Temperature Offset
The on-board RH/T sensor is influenced by thermal self-heating of SCD30 and other electrical components. Design-in alters the
thermal properties of SCD30 such that temperature and humidity offsets may occur when operating the sensor in end-customer
devices. Compensation of those effects is achievable by writing the temperature offset found in continuous operation of the
device into the sensor.
Temperature offset value is saved in non-volatile memory. The last set value will be used for temperature offset compensation
after repowering.
Set Skip Samples (CO2)
This value determines how many samples for the CO2 reading the sensor skips.
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 44 – Wireless CO2 Gas Sensor
- Click on Import
Example Flows
