- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
This long range RS485 to Wireless Converter can be used to connect existing RS485 devices to bring them to a modern IoT framework. This RS485 to Wireless Converter can also be used to replace RS485 wired connections with a reliable long range wireless communication technology. Connect to the NCD wireless sensor ecosystem using the industry standard RS485 communications. Our new IoT RS485 to Wireless Converter makes it easy communicate with NCD wireless sensors over RS485 by simply opening a COM port and watching for incoming data to arrive as sensor data is broadcast. We have stripped away complexity and focused on what you need most, an easy way to get wireless data over a RS485 connection. With a 2-Mile range (line of sight), this device operates at 900MHz for deep penetration through trees, foliage, and even some buildings. With integrated Mesh networking, this device also acts as a repeater for sensor data. Designed to work with any operating system that supports RS485 communications. This RS485 to Wireless Converter offers a wide operating voltage range, requiring a external power supply of 5V to 32VDC.
- Industrial Grade IoT RS485 To Wireless Converter
- Works With VFD, PLC, SCADA systems
- Works With HVAC Control Systems
- Ideal For MODBUS Communication Over Wireless
- Convert any RS485 Sensor/Device into a Wireless Sensor/Device
- API communication over Wireless for Robust Reliability
- Receive Wireless Sensor Data from NCD Sensors
- Ideal For using ncd.io sensors with Gateway With RS485 Port
- Converts Wireless Data to Serial RS485 Data As it Is
- 5V-32VDC Input Voltage Range
- Works With PC, MAC, Linux and Edge Gateway
- Available in 3 Versions for use with PLCs and PCs
Hardware Controls
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 1011,
"sensor_data": {
"0": 127
"1": 0
"2": 11
"3": 236
"4": 0
"5": 80
"6": 25
"sensor_name": "RS485 Wireless Converter",
"type": "sensor_data",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
The payload is dependent on the RS485 device that is connected to the NCD RS485 Wireless Converter. Thus, the number of registers and their values could be pretty much anything, for example:
“0”: 127
“1”: 0
“2”: 11
“3”: 236
“4”: 0
“5”: 80
“6”: 25
The meaning of the values is again dependent on the connected device.
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 1011,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 1011,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 1011,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 1011,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 1011,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_data": {
"0": 127
"1": 0
"2": 11
"3": 236
"4": 0
"5": 80
"6": 25
"original": {...},
"payload": {
"0": 127
"1": 0
"2": 11
"3": 236
"4": 0
"5": 80
"6": 25
"_msgid": "48e99332fc104565"
“0”: 127
“1”: 0
“2”: 11
“3”: 236
“4”: 0
“5”: 80
“6”: 25
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
- OTF Config
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Set Mode
Set the operational mode of the RS485 Converter. Depending on the mode the transmitted data will be different, this is useful as different systems process data differently so you can select the proper mode for your deployment in order to match your existing system.
Auto Encoder Mode (DEFAULT):
In this mode the the data coming from the RS485 device is encapsulated in a DigiMesh packet.
Example Incoming Wireless Data — 7E 00 19 90 00 13 A2 00 41 91 1B 83 FF FE C2 7F 00 04 03 FF 80 03 F3 00 7F A1 F7 40 9E
Data On RS485 Port — 7F 00 04 03 FF 80 03 F3 00 7F A1 F7 40
Refer to the RS485 Converter API Overview document for details on the DigiMesh packet structure.
Transparent Mode:
In this mode the data frame is transmitted exactly as it is received, no modification.
Example Incoming Wireless Data — 7E 00 19 90 00 13 A2 00 41 91 1B 83 FF FE C2 7F 00 04 03 FF 80 00 03 F3 0F A1 F7 40 9E
Data On RS485 Port — 7E 00 19 90 00 13 A2 00 41 91 1B 83 FF FE C2 7F 00 04 03 FF 80 03 F3 00 0F A1 F7 40 9E
As you can see the two data frames are identical.
NCD Emulator Mode:
This mode is similar to the Auto Encoder, however the RS485 Converter pre-pends the following to the RS485 data:
7F – Payload header
00 – Node ID
FF FF — Sensor Type
This device will send data to RS485 port only when the incoming data contains the correct header, node id and sensor type.
Example Incoming Wireless Data — 7E 00 15 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 7F 00 03 F3 85 85 85 E7
Data On RS485 Port — 85 85 85
Example Incoming Data on RS485 port — 69 20 74 68 69 6E 6B 20 69 20 61 6D 20 77 6F 72 6B 69 6E 67 20 66 69 6E 65
Data on Wireless Link — 7E 00 29 90 00 13 A2 00 41 8C 58 B6 FF FE C2 7F 00 03 F3 69 20 74 68 69 6E 6B 20 69 20 61 6D 20 77 6F 72 6B 69 6E 67 20 66 69 6E 65 A2
Default Configurations
| Network ID | 7F FF (HEX) |
| Node ID | 0 |
| Delay | 600 (DEC) seconds |
| Power | +24 dBm |
| Retries | 10 |
| Operational Mode | Auto Encoder |
| Baud Rate | 9600 |
| Byte Size | 8 |
| Parity | None |
| Stop Bits | 1 |
| Data Flow Control | None |
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
We have built an example dashboard to display the sensor data from a single Machine Uptime Monitor. You can find it by importing it directly into Node-Red.
- Import
- Expand Type 108 – Machine Uptime Monitoring Sensor
- Click on Import
Example Flows
