- Device Overview
- Frame Structure
- Read Sensor Network ID
- Appendix
This long range RS485 to Wireless Converter can be used to connect existing RS485 devices to bring them to a modern IoT framework. This RS485 to Wireless Converter can also be used to replace RS485 wired connections with a reliable long range wireless communication technology. Connect to the NCD wireless sensor ecosystem using the industry standard RS485 communications. Our new IoT RS485 to Wireless Converter makes it easy communicate with NCD wireless sensors over RS485 by simply opening a COM port and watching for incoming data to arrive as sensor data is broadcast. We have stripped away complexity and focused on what you need most, an easy way to get wireless data over a RS485 connection. With a 2-Mile range (line of sight), this device operates at 900MHz for deep penetration through trees, foliage, and even some buildings. With integrated Mesh networking, this device also acts as a repeater for sensor data. Designed to work with any operating system that supports RS485 communications. This RS485 to Wireless Converter offers a wide operating voltage range, requiring a external power supply of 5V to 32VDC.
- Industrial Grade IoT RS485 To Wireless Converter
- Works With VFD, PLC, SCADA systems
- Works With HVAC Control Systems
- Ideal For MODBUS Communication Over Wireless
- Convert any RS485 Sensor/Device into a Wireless Sensor/Device
- API communication over Wireless for Robust Reliability
- Receive Wireless Sensor Data from NCD Sensors
- Ideal For using ncd.io sensors with Gateway With RS485 Port
- Converts Wireless Data to Serial RS485 Data As it Is
- 5V-32VDC Input Voltage Range
- Works With PC, MAC, Linux and Edge Gateway
- Available in 3 Versions for use with PLCs and PCs
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Run mode is the default mode of operation of this sensor. In this mode, the RS485 Converter sends periodic packets with the sensor measurement data. During the time it is not sending it enters deep-sleep to conserve power. The sensor’s X-bee module operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 4 illustrates the API transmission/reception procedure.
Auto Encoder Sensor Data Frame
In this mode the the data coming from the RS485 device is encapsulated in a DigiMesh packet.
Example Incoming Wireless Data — 7E 00 19 90 00 13 A2 00 41 91 1B 83 FF FE C2 7F 00 04 03 FF 80 00 01 00 0F A1 F7 40 9E
The data payload is taken out of the DigiMesh frame encapsulation (as per the NCD structure in Figure 4) and is transmitted on the RS485 port.
Data On RS485 Port — 7F 00 04 03 FF 80 00 01 00 0F A1 F7 40
This way only the actual data payload is transmitted on the RS485 port, removing the NCD DigiMesh encapsulation.
| Frame Field | Offset (Payload section) | Fixed Value (if any) | Description |
| Header | 0 | 0x0F | Header to differentiate various types of packets |
| Node ID | 1 | 0x00 (Factory Default) | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| Firmware | 2 | 01 | Used to determine firmware version programmed in the device |
| Battery Voltage | MSB 3 | 03 | Battery Voltage = 0.00322*(03*FF+FE) |
| LSB 4 | FE | Battery Voltage = ((Battery Voltage MSB x 256) + Battery Voltage LSB) x 0.00322 V | |
| Packet Counter | 5 | - | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets |
| Sensor Type | MSB 6 | 0x03 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end. |
| LSB 7 | 0xF3 | Sensor type 1011 | |
| Error/Reserved byte | 8 | 0x00 | For future use |
| Data Payload Bytes | 9 | 0x0F | The value of the payload in HEX form. |
| 10 | 0xA1 | This can take any form as it depends on the device it is connected to. | |
| 11 | 0xF7 | ||
| 12 | 0x40 |
Transparent Sensor Data Frame
In this mode the data frame is transmitted exactly as it is received, no modification.
This data has the standard NCD encapsulation as per Figure 4, where the value in Bold are the actual payload.
Data On RS485 Port — 7E 00 19 90 00 13 A2 00 41 91 1B 83 FF FE C2 7F 00 04 03 FF 80 00 01 00 0F A1 F7 40 9E
As you can see the data on the RS485 Port is exactly the same as the incoming Wireless Data (the encapsulation and payload), nothing is changed or pre/appended.
NCD Emulator Sensor Data Frame
This mode is similar to the Auto Encoder, however the RS485 Converter pre-pends the following to the RS485 data:
7F – Payload header
00 – Node ID
03 F3 — Sensor Type
This device will send data to RS485 port only when the incoming data contains the correct header, node id and sensor type.
Example Incoming Wireless Data — 7E 00 15 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 7F 00 03 F3 85 85 85 E7
Data On RS485 Port — 85 85 85
Example Incoming Data on RS485 port — 69 20 74 68 69 6E 6B 20 69 20 61 6D 20 77 6F 72 6B 69 6E 67 20 66 69 6E 65
Data on Wireless Link — 7E 00 29 90 00 13 A2 00 41 8C 58 B6 FF FE C2 7F 00 03 F3 69 20 74 68 69 6E 6B 20 69 20 61 6D 20 77 6F 72 6B 69 6E 67 20 66 69 6E 65 A2
Configuration Mode Frame
The following set of commands are an example on how to change some of the parameters that affect the operation of the RS485 Converter device (these are parameters that are general in nature, more on a network protocol/device level than device specific). The relate to settings that are independent of the type of probe used. You can find them in Appendix together wit the Device/Application Specific commands.
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78Â
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor PayloadÂ
C. Power Level
0x04 (data byte 23)
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The RS485 Converter sensor will wake up after the predefined sleep time and will try again.Â
B. Complete Sensor PayloadÂ
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05Â
Complete Payload
Appendix
Configuration Commands
| 2 | Set Destination Address | 0XF7 | 0x03 | A0 MSB, A1, A2, A3 | 00,00,FF,FF | Sets the Destination Address of the sensor. The sensor will send Run mode Data packets to this Address |
| 3 | Set Power | 0XF7 | 0x04 | Power ( range 1-4) | 0x04 | Sets the RF power of the Sensor Radio |
| 4 | Set PAN ID aka Network ID | 0XF7 | 0x05 | ID0 MSB, ID1 LSB | 0x7FFF | Sets the PAN ID aka Network ID in the sensor. Only sensors, Gateway, and Modes with Same ID can communicate with each other |
| 5 | Set Retries | 0XF7 | 0x06 | Retries | 0x0A | Sets the number of Retries after unsuccessful transmission for the Sensor Radio |
| 6 | Read Power | 0XF7 | 0x16 | - | 0x04 | Reads the stored RF Power value from the sensor |
| 7 | Read Retries | 0XF7 | 0x17 | - | 0x0A | Reads the stored Retries value from the sensor |
| 8 | Read Destination Address | 0XF7 | 0x18 | - | 00,00,FF,FF | Reads the stored Destination value from the sensor |
| 9 | Read PAN ID aka Network ID | 0XF7 | 0x19 | - | 0x7FFF | Reads the PAN ID aka Network ID |
| 10 | Enable Encryption | 0XF2 | 0x01 | - | 0x01 | Enables the Encryption of the Frame Transmitted from the Sensor |
| 11 | Disable Encryption | 0XF2 | 0x02 | - | - | Disables the Encryption of the Frame Transmitted from the Sensor |
| 12 | Set Encryption Key | 0XF2 | 0x03 | 00,K0 MSB, K1,K2,K3,K4,K5,K6,K7,K8,K9,K10,K11,K12,K13,K14,K15 | 55AA55AA55AA55AA55AA55AA55AA55AA | Sets the 128 bit AES Encryption Key |
| 13 | Set Change Detection Parameters | 0XF7 | 0x07 | E, PR, T0 MSB, T1, T2 LSB | Enable or disable the percentage change detection. E=1 (Enable), E=0 (Disable) PR is the percentage change detection at which the sensor will send a packet. The sensor sends a packet when two consecutive readings differ by PR percent T0, T1, T2 - This is the detection time after which the sensor periodically checks for PR percent change in sensor data from last sample |
| 14 | Read Change Detection Parameters | 0XF7 | 0x1A | - | Refer to Command 15 above for the explanation. |
Command Acknowledgement Data
| 2 | Set Destination Address | 1 | 8 | 0xFF (OK) | |
| 3 | Set Power | 1 | 8 | 0xFF (OK) | |
| 4 | Set PAN ID aka Network ID | 1 | 8 | 0xFF (OK) | |
| 5 | Set Retries | 1 | 8 | 0xFF (OK) | |
| 6 | Read Power | 1 | 8 | Power | DEC value |
| 7 | Read Retries | 1 | 8 | Retries | DEC value |
| 8 | Read Destination Address | 4 | 5 | A0 MSB, A1, A2, A3 | |
| 9 | Read PAN ID aka Network ID | 2 | 7 | ID0 MSB, ID1 | |
| 10 | Enable Encryption | 1 | 8 | 0xFF (OK) | |
| 11 | Disable Encryption | 1 | 8 | 0xFF (OK) | |
| 12 | Set Encryption Key | 1 | 8 | 0xFF (OK) | |
| 13 | Set Change Detection Parameters | 1 | 8 | 0xFF (OK) | |
| 14 | Read Change Detection Parameters | 5 | 4 | E, PR, T0, T1, T2 | Detection time = (T0 x 65536) + (T1 x 256) + T2 |
Application Specific Commands
| COMMAND | COMMAND | SUB COMMAND | Reserve Byte | COMMAND CODE | ARGUMENT |
| SET Baud Rate | 0xF4 | 0x20 | 0x00,0x00,0x17 | 0x0001C200 | Set the Baud Rate to 115200 |
| GET Baud Rate | 0xF4 | 0x23 | 0x00,0x00,0x17 | - | Get the current Baud Rate |
| Set Stop Bits | 0xF4 | 0x22 | 0x00,0x00,0x17 | 0x00 | Set stop bit to 1 |
| Get Stop Bits | 0xF4 | 0x25 | 0x00,0x00,0x17 | - | Get stop bit value |
| Set Parity | 0xF4 | 0x21 | 0x00,0x00,0x17 | 0x00 | Set Parity to None |
| Get Parity | 0xF4 | 0x24 | 0x00,0x00,0x17 | - | Activate Accelerometer |
| Set Mode | 0xF4 | 0x26 | 0x00,0x00,0x17 | 0x00 | Set Mode to Processed |
| Set Mode | 0xF4 | 0x26 | 0x00,0x00,0x17 | 0x01 | Set Mode to RAW |
| Get Mode | 0xF4 | 0x27 | 0x00,0x00,0x17 | - | Get the current Mode |
| Set Address Timer Rate | 0xF4 | 0x28 | 0x00,0x00,0x17 | 0x07D0 | Set Address Timer Rate to 2 seconds |
| Get Address Timer Rate | 0xF4 | 0x29 | 0x00,0x00,0x17 | - | Get Address Timer Rate |
| Set RS IO Delay | 0xF4 | 0x30 | 0x00,0x00,0x17 | 64 | Set RS IO Delay to 100 |
| Get RS IO Delay | 0xF4 | 0x31 | 0x00,0x00,0x17 | - | Get RS IO Delay |
| Reboot | 0xF7 | 0x40 | 0x00,0x00,0x00 | 0x051617 | Reboot the device |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the calculated checksum matches with the checksum sent by the terminal. Let us break the example command below:
0x04
0xFF-0x04=0xFB
Calculation for reception
0xFF
