Explore the Industrial IoT RS485 To Wireless Converter Capabilities
This long range RS485 to Wireless Converter can be used to connect existing RS485 devices to bring them to a modern IoT framework. This RS485 to Wireless Converter can also be used to replace RS485 wired connections with a reliable long range wireless communication technology. Connect to the NCD wireless sensor ecosystem using the industry standard RS485 communications. Our new IoT RS485 to Wireless Converter makes it easy communicate with NCD wireless sensors over RS485 by simply opening a COM port and watching for incoming data to arrive as sensor data is broadcast. We have stripped away complexity and focused on what you need most, an easy way to get wireless data over a RS485 connection. With a 2-Mile range (line of sight), this device operates at 900MHz for deep penetration through trees, foliage, and even some buildings. With integrated Mesh networking, this device also acts as a repeater for sensor data. Designed to work with any operating system that supports RS485 communications. This RS485 to Wireless Converter offers a wide operating voltage range, requiring a external power supply of 5V to 32VDC.
- Industrial Grade IoT RS485 To Wireless Converter
- Works With VFD, PLC, SCADA systems
- Works With HVAC Control Systems
- Ideal For MODBUS Communication Over Wireless
- Convert any RS485 Sensor/Device into a Wireless Sensor/Device
- API communication over Wireless for Robust Reliability
- Receive Wireless Sensor Data from NCD Sensors
- Ideal For using ncd.io sensors with Gateway With RS485 Port
- Converts Wireless Data to Serial RS485 Data As it Is
- 5V-32VDC Input Voltage Range
- Works With PC, MAC, Linux and Edge Gateway
- Available in 3 Versions for use with PLCs and PCs
| Width | 2.50" | |||
| Length | 2.50" | |||
| Height | 0.90" | |||
| Probe Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Input Voltage Range | 5VDC | 32VDC | Works with either DC or AC |
RF Module Specifications
This device is has not been designed to run on batteries and can only work with an External power supply (5-32V AC/DC Power Input).
Head to the NCD store if you want to purchase the Industrial IoT RS485 To Wireless Converter.
