NCD.io › Documentation › Smart Vibration Sensor Gen4
Atrium · Smart Vibration Gen4
3-axis industrial vibration and temperature monitoring with on-board FFT, always-listening Smart Mode transmission, and Atrium IIoT Gateway integration. Configurable sample rate up to 25.6 kHz over its long-range wireless mesh. SKU PR63-3A.
Buy Now →
Sensor Type
Vibration / Temperature (Atrium type 114)
Last updated
2026-07-10
01Overview
The NCD Industrial IoT Wireless Smart Vibration Sensor Gen4 is a battery-powered, 3-axis vibration and temperature monitor built for predictive maintenance on rotating equipment — motors, pumps, fans, compressors, and gearboxes. It samples acceleration on all three axes, performs FFT analysis on-board, and transmits processed vibration metrics (RMS acceleration, velocity, displacement, peak frequencies), temperature, and RPM over a long-range wireless mesh network to an Atrium IIoT Gateway. In Smart Mode the sensor is always listening: it continuously monitors vibration and transmits when RMS acceleration crosses a configurable threshold, sending a periodic keep-alive in between so the gateway knows it is online — conserving battery. (See how Smart Mode transmission works.)
The sensor ships with one of three wireless communication modules. Choose the frequency band that matches your gateway and region — the sensor core, firmware, and Atrium integration are identical across all three. The 900 MHz and 868 MHz options run on NCD’s sub-GHz wireless mesh network, which cuts through industrial noise and interference for secure, long-range communication.
Wireless ModuleRegionLine-of-Sight RangeIndoor Range
900 MHzNorth America~2 miles~1,000 ft
868 MHzEurope~2 miles~1,000 ft
2.4 GHzWorldwide certified~1 mile~300 ft
3-Axis, up to 25.6 kHz
Simultaneous X/Y/Z acceleration sensing with a configurable output data rate from 100 Hz to 25.6 kHz and a 70 µg/√Hz noise floor.
Always-Listening Smart Mode
On-board FFT plus an always-listening transmission mode — the sensor monitors continuously and transmits only when vibration crosses a configurable threshold, with periodic keep-alives, cutting transmissions and extending battery life.
Multi-Year Battery Power
D-cell (LR20) lithium pack with integrated supercapacitor — up to 5 years; estimate for your configuration with NCD’s battery life calculator. Battery-powered only — no external power input or wiring required.
IP67 Rugged Enclosure
Sealed stainless steel enclosure rated IP67. Magnetic base for tool-free attachment to ferrous machine surfaces, or 1/4″–28 UNF threaded stud mount for permanent coupling.
What’s in the Box
  • Industrial IoT Wireless Smart Vibration Sensor Gen4 with pre-installed D-cell (LR20) battery and integrated supercapacitor
  • Wireless communication module per your selection (900 MHz, 868 MHz, or 2.4 GHz)
  • Internal antenna — no external antenna to attach
02Specifications
Full technical specifications for the Smart Vibration Sensor Gen4 (SKU PR63-3A). Values are drawn from the product datasheet and user manual; where sources differ, both figures are noted.
ParameterSpecification
Sensing Axes3-axis (X, Y, Z) accelerometer
Full-Scale Range±8g default; up to ±16g (3-axis accelerometer)
Output Data Rate (sample rate)100 Hz to 25.6 kHz, configurable (default 12.8 kHz)
Noise Floor70 µg/√Hz
Max Raw SampleUp to 8192 samples; default 4096 (time-domain / FFT analysis)
Sample DurationDepends on the configured sample rate (ODR)
RPM MeasurementCalculated from acceleration data; up to 6000 RPM (reads 0 below 30 mg)
Temperature SensorIntegrated in base; temperature-compensated
Temperature Measurement Range–40°C to +70°C rated (0°C to +40°C tested)
Temperature Accuracy±1°C
Enclosure Operating Temp−40°C to 85°C (enclosure/electronics)
Wireless ModuleSelect 900 MHz (North America), 868 MHz (Europe), or 2.4 GHz (worldwide) at time of order
Line-of-Sight Range~2 miles (900/868 MHz); ~1 mile (2.4 GHz)
AntennaInternal — no external antenna
Encryption128-bit AES
Enclosure RatingIP67
Enclosure MaterialStainless steel
Dimensions~85 mm (3.3″) height × ~48 mm (1.9″) base diameter
Weight~225 g
MountingMagnetic base or 1/4″–28 UNF threaded stud
Power SupplyBattery only — D-cell LR20 lithium, 16,000 mAh, with integrated supercapacitor (~3.28 V nominal). No external power input.
Battery LifeUp to 5 years — varies with configuration. Estimate for your settings with the battery life calculator
Default Sampling Interval30 minutes (configurable)
SKU / UPCPR63-3A / 689860069954
03Prerequisites
Before installing this sensor, make sure you have the following in place.
Hardware Required
  • NCD Atrium IIoT Gateway — powered on and connected to your local network
  • Smart Vibration Sensor Gen4 (this unit) with the wireless module installed (internal antenna — nothing to attach)
  • A clean, flat mounting point on the monitored asset — magnetic surface or a tapped 1/4″–28 UNF hole for stud mounting
Software / Network
  • A current version of Atrium running on your gateway
  • A computer or mobile device on the same local network as the gateway
  • A modern web browser (Chrome recommended)
04Mounting & Installation
Mounting quality directly affects vibration data quality. The sensor must be rigidly coupled to the asset so that machine vibration transfers faithfully to the accelerometer. Loose, padded, or indirect mounting attenuates high-frequency content and degrades FFT accuracy.
Powering On
  1. 1
    Confirm power
    The Gen4 ships battery-installed and powered on in Run Mode. To verify power without opening the enclosure, activate the magnetic CFG switch with a magnet — the TEST LED illuminates while a magnet is present, confirming the battery is connected and the unit is live.
  2. 2
    Power cycle if needed
    If the unit needs a restart (for example after long storage), trigger the magnetic RESET switch with a magnet, then remove the magnet. The sensor reboots into Run Mode and resumes sampling.
01 sensor exterior
The sealed Gen4 sensor — magnetic base and the external RESET/CFG magnetic-switch locations. The enclosure stays closed in normal use.
Mounting the Sensor
  • Magnetic mount: The base is a strong magnet that attaches directly to any flat, clean ferrous surface (motor housing, pump body, equipment frame). Remove by rotating the sensor counterclockwise by hand — do not pry. Best for surveys and temporary monitoring.
  • Threaded stud mount: For permanent installation, mount to a tapped 1/4″–28 UNF hole using a threaded stud. This gives the most rigid coupling and the best high-frequency response.
05Pairing with Atrium
Once powered on, the sensor transmits over its long-range wireless mesh and the gateway begins hearing it. New sensors are held pending (blacklisted) until you whitelist them through the Sensor Details wizard — data is not logged until a sensor is whitelisted. The wizard walks you through naming and whitelisting each detected sensor.
  1. 1
    Power on and mount the sensor
    Confirm the sensor is powered (TEST LED on CFG activation) and mounted. Within one sampling interval, the gateway will begin receiving its transmissions.
  2. 2
    Open Atrium and go to Sensors
    Navigate to your gateway’s local address (e.g. http://ncd-[last-4-of-MAC].local) and click Sensors in the top navigation. A banner shows “X sensors need setup” with detected sensors grouped by type. Your unit appears under the Vibration sensor type.
  3. 3
    Open the Sensor Details wizard
    Click the sensor in the banner (or in the Sensors table) to open the Sensor Details wizard. New sensors start pending (blacklisted) — completing the wizard whitelists the sensor so Atrium begins logging its data.
  4. 4
    Enter details and save
    Give the sensor a Sensor Name, Asset, and Location (see Section 6). Use Save to whitelist and finish, Save & Next to move to the next pending sensor, or Skip to leave a sensor pending for now.
  5. 5
    Confirm it is reporting
    The whitelisted sensor now appears in the Sensors table with a recent Last Heard timestamp. Open its Dashboard to confirm live vibration and temperature data.
02 sensors needs setup
Atrium detects new sensors automatically and lists them in the “sensors need setup” banner, grouped by type.
03 setup wizard sensors
The Sensor Details wizard — complete it to whitelist the sensor. Use Save, Save & Next, or Skip.
06Sensor Meta
The Sensor Meta tab controls how Atrium identifies and tracks this sensor. Access it via Sensors → [your sensor] → Configure → Sensor Meta.
FieldDescription
Sensor StatusWhitelisted — data is logged and displayed. Blacklisted — data is ignored. New sensors are blacklisted (pending) until whitelisted via the Sensor Details wizard.
Sensor NameHuman-readable label shown throughout the Atrium interface (e.g. “Pump 2 — Drive End”).
AssetThe asset or equipment this sensor is monitoring (e.g. “Coolant Pump 2”).
LocationPhysical location of the sensor (e.g. “Plant 1 — Pump Room”).
Report Interval (seconds)Must match the sampling/transmission interval configured in Sensor Hardware Settings. Atrium marks the sensor offline if no data is received within 2× this value.
Install DateOptional. Records when the sensor was deployed.
Offline AlertWhen enabled, Atrium sends an email notification if the sensor stops reporting. Requires email configured in Settings → Gateway Configuration.
07Metric Configuration
The Metrics tab lets you configure conversion formulas, units, custom labels, and dashboard visibility for each data channel. Access it via Configure → Metrics. The Gen4 reports a rich set of vibration metrics on each of the three axes, plus environmental and packet-metadata channels.
Vibration Metrics (per X / Y / Z axis)
MetricUnitDescription
RMS AccelerationgRoot-mean-square acceleration per axis — the primary overall-vibration trend metric
Peak (Max) AccelerationgMaximum acceleration observed in the sample window, per axis
Velocitymm/secDerived RMS velocity per axis — the standard ISO measure for machine-health trending
DisplacementmmDerived peak-to-peak displacement per axis
Peak Frequency 1 / 2 / 3HzThe frequencies of the three highest-energy peaks from the on-board FFT, per axis
Environmental & Operational Metrics
temperature°C or °FBase temperature (display unit set globally — see Section 9)
RPMrev/minRotational speed calculated from acceleration over a 3-second window; reads 0 below 30 mg
battery_pct%Estimated remaining battery capacity
battery_vVBattery voltage (separate from battery_pct; ~3.28 V nominal, drops off quickly below 2.6 V)
rssidBmReceived signal strength — reported as a positive magnitude; higher values mean a weaker signal
counter—Transmission counter (0–255, then rolls over); useful for detecting missed packets
Custom Conversion Formulas
Each metric supports a custom conversion formula using value as the variable name. Leave the formula as value or blank to display raw data. Examples:
Formula examples
value * 25.4          // Convert displacement mm to mils (thousandths of an inch)
value / 9.80665       // Convert acceleration in m/s² to g
value * 60            // Convert a per-second rate to per-minute
Custom Labels & Visibility
Each metric can be assigned a Custom Label that replaces the default metric name throughout Atrium. Unchecking Visible on Dashboard hides that metric’s card and chart without deleting data — useful for focusing a vibration dashboard on the few axes and channels that matter for a given asset.
04 metrics config
Metric Configuration — each metric exposes a conversion formula, unit, custom label, and a dashboard-visibility toggle (one metric shown).
08Hardware Settings
Hardware settings control the sensor’s on-board configuration — operating mode, sampling, filtering, thresholds, and network addressing. Changes are staged in Atrium and pushed to the sensor on its next configuration check-in. Access via Configure → Sensor Configuration.
Operating Mode
The Gen4 supports four operating modes. Choose the mode that matches your monitoring goal and battery budget:
ModeNameBehavior
0ProcessedFFT performed on-board; condensed time- and frequency-domain data transmitted each interval
1Raw / Time DomainFull time-domain samples transmitted; FFT performed by the client. Highest data volume
2On DemandProcessed data at intervals, with raw time-domain data available on request
3Smart (always listening)The sensor listens continuously and transmits only when RMS acceleration crosses the Smart Mode threshold, with a periodic keep-alive so the gateway knows it is online. Lowest battery use
Key Configuration Parameters
SettingDefaultDescription
Output Data Rate (ODR)12800 HzAccelerometer sample rate, 100 Hz–25.6 kHz. Higher ODR resolves higher-frequency faults but uses more power.
Sample Count4096Number of samples captured per reading for time-domain / FFT analysis. Configurable up to 8192.
Sampling Interval30 minHow often the sensor takes and transmits a reading (Run/Processed modes).
Full Scale Range8 gAccelerometer measurement range (±8g default; selectable up to ±16g).
Acceleration Dead Band20 mgUser-configurable. Sets the minimum acceleration registered — readings below the dead band are reported as 0.
Wake / Interrupt Threshold500 mgAcceleration level that wakes the sensor to sample and broadcast (Smart Mode).
Smart Mode Threshold500 mgRMS acceleration above which Smart Mode transmits.
Smart Mode Skip Interval3Number of intervals to skip transmission while below threshold.
Low/High Pass FilterLPF 4 / HPF 2048Filter coefficients (cutoff = ODR / coefficient); filtering enabled by default.
RPM CalculationEnabledDerives RPM from acceleration; disable if not monitoring a rotating asset.
Network IDuser-setWireless network ID. Must match the gateway’s network ID. (Configuration mode temporarily uses 7BCD.)
Destination Address0000FFFFBroadcast address the sensor transmits to. Left at default for standard mesh topologies.
FLY Interval60 minHow often the sensor opens a brief configuration check-in window (on boot and hourly).
Adjusting the Sampling Interval
  1. 1
    Go to Sensor Configuration
    Navigate to Sensors → [your sensor] → Configure → Sensor Configuration.
  2. 2
    Update the interval and mode
    Set your desired sampling interval and operating mode. Shorter intervals and higher ODR give more data at the cost of battery life.
  3. 3
    Click Save Hardware Settings
    The new values are staged and pushed to the sensor on its next FLY (configuration check-in) window — up to one FLY interval (default 60 minutes).
  4. 4
    Update the Report Interval in Sensor Meta
    Update the Report Interval on the Sensor Meta tab to match your new transmission cadence so offline detection stays accurate.
Battery Life
The sensor delivers up to 5 years of battery life. Actual life depends on your configuration — sample rate (ODR), transmission interval, and operating mode all affect it. Higher ODR and shorter intervals draw more power; Smart Mode extends life on assets that are frequently idle, since it transmits only on threshold events plus keep-alives. To estimate battery life for your exact settings, use NCD’s battery life calculator. For continuous high-rate monitoring, run the sensor on external power.
05 hardware settings
Sensor Configuration tab showing operating mode, sampling, and network settings.
09Temperature Units
The Gen4 reports base temperature alongside its vibration metrics. Atrium provides a global temperature display unit setting that controls how temperature readings appear across the entire interface — all sensors, dashboards, alerts, and reports.
  1. 1
    Open Gateway Settings
    Click Settings in the top navigation to open Gateway Configuration.
  2. 2
    Select Temperature Display Unit
    Under Temperature Display Unit, toggle between °C and °F. This applies immediately to all temperature readings across Atrium.
  3. 3
    Save Configuration
    Click Save Configuration at the bottom of the page to apply the change.
06 gateway settings temp unit
The Temperature Display Unit toggle in Gateway Settings applies to all sensors globally.
10Sensor Dashboard
The Sensor Dashboard provides a real-time and historical view of all data from this sensor. Access it by clicking the sensor in the Sensors list and selecting Dashboard.
Live Metrics
RMS Velocity (X/Y/Z)mm/secPrimary machine-health trend; compare against ISO severity bands
Peak Acceleration (X/Y/Z)gHighest acceleration in the sample window; surfaces impacts and high-frequency faults
Peak FrequencyHzDominant FFT frequencies — map to fault frequencies (imbalance, bearing, gear mesh)
Temperature°F or °CBase temperature of the monitored asset
RPMrev/minCalculated rotational speed (0 when below 30 mg)
Battery Pct%Estimated remaining battery capacity
RSSIdBmSignal strength as a positive magnitude — higher values mean a weaker signal
Time Range & Charts
Use the time range selector to view historical data for the last hour, 6 hours, 24 hours, 7 days, or 30 days. A custom date/time range is also available. Each metric has its own interactive chart — drag to zoom into a time window, double-click to reset. Trend RMS velocity over weeks to catch developing faults early.
07 sensor dashboard
Sensor Dashboard showing live vibration, temperature, RPM, battery, and signal metrics.
Mesh Route Map
Click View Map in the Mesh Route Map panel to visualize how this sensor’s data routes through the wireless mesh to reach the gateway. Useful for diagnosing signal path issues in multi-sensor deployments.
Interactive Preview
The panel below simulates the Atrium Sensor Dashboard for this Vibration / Temperature sensor. Data updates every 5 seconds to demonstrate the live monitoring experience.
11Setting Alerts
Atrium uses a Triggers & Actions model for alerting. A Trigger defines the threshold condition on a metric. An Action defines what happens when all assigned triggers fire. Navigate to Alerts in the top navigation (the page is titled Alerts & Actions) to configure.
Creating a Trigger
  1. 1
    Go to Alerts → Triggers
    Click + New Trigger to open the Create Trigger form.
  2. 2
    Configure the trigger
    Select the Device, Metric (e.g. RMS velocity, peak acceleration, or temperature), Condition (Above or Below), and Threshold value. The Reset At column sets the value the metric must return to before the trigger can fire again — this hysteresis prevents repeated firing when the value oscillates near the threshold. Click Create Trigger.
Creating an Action
  1. 1
    Go to Alerts → Actions
    Click + New Action. Actions link one or more triggers to a response — when all assigned triggers fire simultaneously, the action executes.
  2. 2
    Assign triggers and configure the response
    Select the trigger(s) to watch and configure the response. Atrium supports email notifications and relay output actions (to drive an external relay, e.g. shut down or signal equipment). Email must be configured in Settings → Gateway Configuration for email actions to work.
08 set alert
The Alerts & Actions page — create a Trigger to define the threshold (with a Reset At value), then an Action to define the response.
12Exporting Data
All sensor data can be exported to CSV directly from the Sensor Dashboard for use in spreadsheets, reporting tools, or vibration-analysis software.
  1. 1
    Open the Sensor Dashboard
    Navigate to the sensor and click Dashboard.
  2. 2
    Select a time range
    Choose the time range you want to export using the selector at the top of the dashboard.
  3. 3
    Click “CSV” on the desired metric
    Each metric chart has a CSV download button. Click it to download a timestamped CSV of that metric’s data for the selected time range. Export velocity and acceleration channels for offline trend analysis.
13Product Notes
Reference information for ordering and accessories.
ItemDetail
BatteryD-cell (LR20) lithium, 16,000 mAh, with integrated supercapacitor — field-replaceable
Spanner WrenchOptional service accessory — only needed to open the enclosure for battery replacement
Receiver OptionsAtrium IIoT Gateway, Enterprise IIoT Gateway / Lite, or NCD Wireless-to-USB / Wireless-to-Ethernet modem
MountingMagnetic base (included) or 1/4″–28 UNF threaded stud
Buy Now on store.ncd.io →
14Troubleshooting
Common issues and their solutions.
Sensor not appearing in Atrium
  • Confirm the sensor is powered — activate the magnetic CFG switch and check that the TEST LED illuminates.
  • Verify the sensor’s wireless frequency (900/868 MHz or 2.4 GHz) matches the gateway’s radio.
  • Verify the sensor’s Network ID matches the gateway’s Network ID. (Note: while in Configuration mode the sensor temporarily uses Network ID 7BCD.)
  • Move the sensor closer to the gateway to rule out range issues — test within 10 feet first.
  • Check that the Atrium gateway is powered on and connected to your network.
Sensor showing as Offline in Atrium
  • Verify the Report Interval in Sensor Meta matches the sensor’s transmission interval in Hardware Settings. In Smart Mode, allow for the keep-alive cadence so quiet periods aren’t read as an outage.
  • Check the battery_pct on the last received reading — replace the battery if low. Note battery_v drops off quickly once it falls below ~2.6 V.
  • Check the RSSI value — remember higher numbers mean a weaker signal. Readings consistently above 75 dBm indicate marginal signal; reposition the sensor or gateway, or add a repeater node.
Vibration or RPM reading looks wrong
  • RPM reads 0: expected when acceleration is below 30 mg (machine idle or very low vibration), or if the asset isn’t rotating. Confirm RPM Calculation is enabled in Hardware Settings.
  • Readings unexpectedly low / zero: check mounting — a loose magnet, painted surface, or padded mount attenuates vibration. Re-seat the sensor on bare, flat metal. Confirm the Acceleration Dead Band isn’t masking the real signal.
  • High-frequency faults missing: raise the Output Data Rate (ODR) so the band of interest is within range, and verify the full-scale range isn’t clipping high-amplitude events.
  • Allow the machine to reach normal operating conditions before trusting trend comparisons.
Hardware settings not updating on sensor
  • Settings are staged and applied on the sensor’s next configuration check-in (FLY window) — wait up to one FLY interval (default 60 minutes) after saving.
  • To apply changes immediately, power-cycle the sensor with the magnetic RESET switch, which opens a configuration window on boot.
  • Confirm the sensor is actively transmitting by checking the Last Heard timestamp on the dashboard.
15Factory Reset
A factory reset restores the sensor’s wireless module to default settings. This is useful if the sensor is not being detected by a gateway, or if you are redeploying it to a new network. The magnetic switch method is recommended — no disassembly required. Reset behavior is governed by how long the CFG switch is held after a RESET.
CFG hold time (after RESET)Result
Less than 5 secondsNormal Run Mode
5 to 15 secondsConfiguration Mode only (Network ID temporarily 7BCD)
More than 15 secondsFactory reset to defaults, then Configuration Mode
Option A — Magnetic Switches (no disassembly)
  1. 1
    Trigger the RESET switch
    Hold a magnet near the RESET magnetic switch, then move it away.
  2. 2
    Wait 1 second
    Allow approximately 1 second before proceeding.
  3. 3
    Hold the CFG switch for ~20 seconds
    Hold the magnet near the CFG magnetic switch for approximately 20 seconds, then move it away. The hold must exceed 15 seconds to trigger a factory reset — a shorter hold only enters Configuration Mode.
  4. 4
    Wait 3–5 seconds
    Allow 3–5 seconds for the reset to complete.
  5. 5
    Trigger the RESET switch again
    Hold the magnet near the RESET switch once more, then move it away. This returns the sensor to normal Run Mode.
Option B — Physical Buttons (requires opening enclosure)
  1. 1
    Open the enclosure
    Open the sensor enclosure to expose the PCB (use the optional spanner wrench if required).
  2. 2
    Press and release the RESET button
    Press and release the RESET button on the PCB.
  3. 3
    Wait 1 second, then hold CFG for ~20 seconds
    Wait approximately 1 second, then press and hold the CFG button for approximately 20 seconds. The hold must exceed 15 seconds to trigger a factory reset. Release the button when done.
  4. 4
    Wait 3–5 seconds
  5. 5
    Press RESET, then close the enclosure
    Press and release the RESET button to return the sensor to normal operation. Re-seal the enclosure.
