NCD’s C1D2 certified long-range wireless water detection sensors are the first designed specifically for hazardous environments. Certified for C1D2 Groups A, B, C, and D, they are suited for areas with explosive gases, dust, fibers, or flammable vapors, including substances like Acetylene, Hydrogen, Gasoline, and Methanol. These sensors are ideal for use in chemical plants, oil refineries, paint shops, mills, and other facilities handling flammable materials.
Featuring an integrated antenna and up to a 2-mile range, the sensor uses a 900MHz 128-Bit AES encrypted transceiver to send data at customizable intervals. It sleeps between transmissions to save power, waking every 15 minutes or when a wet/dry condition is detected. This ensures regular updates and immediate alerts, with a battery life of up to 10 years depending on conditions and settings.
The sensor includes a 4.5-meter probe cable, transmitting wet or dry status changes for applications like water leak detection. It is ideal for preventing water damage in buildings or monitoring drainage in critical areas. Applications include detecting floods, leaks from water heaters, frozen pipes, or low-water conditions in sensitive areas like factory floors and machinery.
NCD’s sensor ecosystem integrates seamlessly with platforms like AWS®, Microsoft Azure®, or private MQTT brokers using Node-RED. This allows secure, private data handling or cloud integration with minimal effort, making it one of the most versatile and reliable solutions on the market.
Feature
- C1D2 Certified Temperature Sensor for Hazardous Locations
- Group A, B, C, and D Certification
- Industrial Long Range Wireless Water Detect Sensor
- Detect Water Presence or non- presence
- IP65 Box Ideal for Indoor Outdoor Applications
- 4.5 Meter Long Connecting Wire Water Detection Probe
- Encrypted Communication, 1000 ft indoor wireless range, approximately 2 miles in line of sight environments with onboard antenna
- Open Communication Protocol for Easy Software Integration,
| Width | 3.56" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
RF Module Specifications
Probe Specifications
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD (TPD Transmissions per Day) | 10 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 12 TPD (TPD Transmissions per Day) | 8 Years | Battery estimation is based on a 30 min interval | ||
| Battery Life 24 TPD (TPD Transmissions per Day) | 5 Year | Battery estimation is based on a 30 min interval | ||
| Battery Life 96 TPD (TPD Transmissions per Day) | 3 Year | Battery estimation is based on a 30 min interval |
C1D2 Industrial IoT Wireless Water Detect Sensor.
