C1D2 Industrial IoT Wireless Water Detect Sensor User Manual
NCD’s C1D2 certified long-range wireless water detection sensors are the first designed specifically for hazardous environments. Certified for C1D2 Groups A, B, C, and D, they are suited for areas with explosive gases, dust, fibers, or flammable vapors, including substances like Acetylene, Hydrogen, Gasoline, and Methanol. These sensors are ideal for use in chemical plants, oil refineries, paint shops, mills, and other facilities handling flammable materials.
Featuring an integrated antenna and up to a 2-mile range, the sensor uses a 900MHz 128-Bit AES encrypted transceiver to send data at customizable intervals. It sleeps between transmissions to save power, waking every 15 minutes or when a wet/dry condition is detected. This ensures regular updates and immediate alerts, with a battery life of up to 10 years depending on conditions and settings.
The sensor includes a 4.5-meter probe cable, transmitting wet or dry status changes for applications like water leak detection. It is ideal for preventing water damage in buildings or monitoring drainage in critical areas. Applications include detecting floods, leaks from water heaters, frozen pipes, or low-water conditions in sensitive areas like factory floors and machinery.
NCD’s sensor ecosystem integrates seamlessly with platforms like AWS®, Microsoft Azure®, or private MQTT brokers using Node-RED. This allows secure, private data handling or cloud integration with minimal effort, making it one of the most versatile and reliable solutions on the market.
  • C1D2 Certified Temperature Sensor for Hazardous Locations
    • Group A, B, C, and D Certification
  • Industrial Long Range Wireless Water Detect Sensor
  • Detect Water Presence or non- presence
  • IP65 Box Ideal for Indoor Outdoor Applications
  • 4.5 Meter Long Connecting Wire Water Detection Probe
  • Encrypted Communication, 1000 ft indoor wireless range, approximately 2 miles in line of sight environments with onboard antenna
  • Supports Wireless Mesh Networking
  • Open Communication Protocol for Easy Software Integration,
  • NO Monthly Fee or Locked Proprietary Protocols, Open Node-RED library for ease of configuration and data processing
Hardware Controls
Power Switch
  • Battery Power
  • Off
  • External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Using Buttons
  • Wait for 3-5 seconds
Using Magnetic Switches
  • Wait for 1 second
Timing Using Buttons
Click to enlarge
Default Configuration
ParametersDefault Value
Destination Address00 00 FF FF (HEX)
Network ID7F FF (HEX)
Node ID0
Delay600 (DEC) seconds
Power+24 dBm
Retries10
Input Debounce Time25 msec
Wireless Gateway Nodes
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 2,
    "sensor_data": {
        "input_1": 1,
        "input_2": 1
    "sensor_name": "2 Channel Push Notification",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
  • input_1
    • A binary value, where 1 means there is a leak, 0 means the sensor is dry
  • input_2
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
    • Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 2,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 2,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 2,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 2,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 2,
    "nodeId": 0,
    "mode": "FLY",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
  • topic
  • payload
  • time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
Click to enlarge
Wireless Device Nodes
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 2,
    "sensor_data": {
        "input_1": 1,
        "input_2": 1
    "original": {...},
  "payload": {
         "input_1":1,
         "input_2":0
  "_msgid": "48e99332fc104565"
msg.payload Breakdown
  • input_1
  • input_2
  • topic
  • payload
  • payload.x
  • time
  • addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
  • topic
  • time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes
  • Serial Device for Config
  • Mac Address
  • Sensor Type*
  • Auto Config
*Required
General Sensor Configurations
  • Wait for Network Formation
  • Destination Address
  • Network ID
  • Node ID and Delay
    • Node ID
    • Delay
  • Power
  • Retries
Set Input Debounce Time
Sets the debounce time in milliseconds on inputs. State changes to the input during this debounce time will be ignored. Generally recommended for mechanically triggered state changes such as button or relay/contactor outputs.
Serial Connection
  1. Name
  2. Modem Type
  3. Serial Port
  4. Baud Rate
  5. Network ID
    • The default value is 7FFF
TCP Socket Connection
  1. Name
  2. Modem Type
  3. TCP Port
  4. IP Address
  5. Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Press and release the RESET button and and then wait for a second, hold the CFG button for > 15 seconds
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
  2. Import
  5. Expand Type 02 – 2 Channel Push Notification
  8. Click on Import
Example Flows
