Feature
| Width | 3.28" | |||
| Length | 4.30" | |||
| Height | 2.16" | |||
RF Module Specifications
| Batteries size | 9000mAh | This device has a single large battery | ||
Industrial Wireless Thermocouple High Temperature Sensor.
