- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Default Configuration
| Network ID | 7F FF (HEX) |
| Node ID | 0 |
| Delay | 600 (DEC) seconds |
| Power | +24 dBm |
| Retries | 10 |
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 12,
"sensor_type": 04,
"sensor_data": {
"channel_1":111,
"channel_2":130,
"channel_3":150
"sensor_name": "3-Channel Thermocouple",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
- channel_1
- The measured temperature in Celsius in channel 1
- channel_2
- The measured temperature in Celsius in channel 2
- channel_3
- The measured temperature in Celsius in channel 3
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 12,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 12,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 12,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 12,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 12,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 12,
"sensor_data": {
"channel_1":111,
"channel_2":130,
"channel_3":150
"original": {...},
"payload": {
"channel_1":111,
"channel_2":130,
"channel_3":150
"_msgid": "48e99332fc104565"
- channel_1
- channel_2
- channel_3
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
*Required
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 12 – 3-Channel Thermocouple Notification
- Click on Import
Example Flows
