Wireless RTD Temperature Sensor Transmitter
RTD Temperature Sensors Made Simple
Wireless RTD Sensor Transmitter with Integrated 15bit ADC makes it easy to connect to any 2 Wire, 3 Wire, and 4 Wire PT100 or PT1000 RTD. Powered by AA batteries, this Transmitter box can read data from any PT100 or PT1000 RTD and send it over wireless to PC, Local Server, or Cloud Services Like AWS, Azure, and MQTT.
- Works with Any RTD
- Easy to Interface
- No Monthly Fees
- User has Complete control over where Data lives
- Long Range Encrypted Wireless communication
- Powered By AA batteries or Option External DC power
Our Wireless RTD Temperature Sensor Transmitter
NCD manufactures single probe and Dual probe RTD temperature Transmitter. A long with Transmitter, we also have a line of data receivers like USB, Ethernet, RS232, RS485, Cellular, and Wifi.
Our Wireless RTD Temperature Transmitter and Receivers are manufactured in the U.S.A. for higher quality standards. We’ve been in the industry for more than 25 years so you know you will be getting a professional products.
$282.95 - $303.95Why Choose NCD?
How It Works
Our idea is simple. We build Industrial Grate RTD temperature Sensor transmitters and revivers to go along with these. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever-expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can communicate to the sensor like it was built into your platform.
About Digimesh Wireless Protocol
It’s designed for creating simple, reliable, and low-power mesh networks. Here are some key points about DigiMesh:
- Mesh Networking
- Security
- Long Range
- Low power
In essence, DigiMesh offers a robust and efficient way to set up wireless communications, particularly in challenging environments where nodes might be out of direct communication range or where network topology might change over time.
Cloud Option to Collect Wireless RTD Temperature Sensor Data
- Enterprise Edge Gateway
- AWS
- Azure
- MQTT
- Or any other cloud Services
Use ncd.io Enterprise Gateway to push data to any cloud service you choose. The gateway is equipped with Ethernet, WiFi, and Cellular connectivity.
Local Data Collection Option to Collect Wireless RTD Temperature Sensor Data
