Wireless RTD sensor with Node Red
Wireless RTD Sensor with Node Red
Getting started with node red and RTD
In this article we will learn how to install and setup node red.
  1. install node js
    https://nodejs.org/en/
  2. install NVM
    https://github.com/coreybutler/nvm-windows/releases
  3. open command line and switch to node js 12.20.2
    nvm install 12.20.2
    nvm use 12.20.2
  4. install node red
    npm install -g --unsafe-perm node-red
    Checkout this article for more info
How to install node red lib
  1. start node red
    command — node-red
  2. open a web browser and enter this
    http://127.0.0.1:1880/
  3. How to install node red lib
  4. click manage palette and search for ncd-red-wireless
  5. install ncd-red-wireless
  6. install node-red-dashboard
Build node red flow
There are tons of examples and tutorials available on how to build flows. In this article we will focus on RTD.
Build node red flow
RTD sensor properties can be changed by clicking on “Wireless RTD”
go to dashboard
RTD sensor properties can be changed by clicking on “Wireless RTD” Dashboard RTD sensor properties can be changed by clicking on “Wireless RTD” Dashboard 2
RTD sensor properties can be changed by clicking on “Wireless RTD” Dashboard 3
In my setup i have few other devices running as well.
Flow to Copy
If you want to use the flow i build
Flow to Copy
Click Import and copy this flow
					[{"id":"6ad9e9a5.d2d478","type":"ui_chart","z":"4a4e93ac.53ff0c","name":"","group":"51153c99.a95fa4","order":1,"width":0,"height":0,"label":"Temperature","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"-40","ymax":"500","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"604800","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":910,"y":460,"wires":[[]]},{"id":"51153c99.a95fa4","type":"ui_group","name":"Wireless RTD","tab":"fd773a63.c42cd8","order":1,"disp":true,"width":"6","collapse":false},{"id":"fd773a63.c42cd8","type":"ui_tab","name":"RTD","icon":"dashboard","disabled":false,"hidden":false}]
