NCD Wireless Relay Controllers
NCD is the worlds largest manufacturer of wireless relay controllers. We offer more wireless protocol options than any other company in the world! Our Industrial Relays offer a modular communication interface, allowing you to upgrade to other communication technologies as your needs change. Simply select the relay controller you need and choose the desired wireless interface for it.
- Available Wireless Protocols:
- WiFi
- Bluetooth
- 900HP-S3B 900MHz Long Range Industrial Mesh
- 802.15.4
- ZigBee Mesh
- Remote Key Fob
- Supports 2-way communications
- 1 to 32 Channel versions available
- Optional A/D, Digital IO, and Expansion Ports
- API allows single or multi-relay control commands
Wireless Relays using WiFi Communications
NCD WiFi Relay controllers offer a popular solution for wireless relay control. Send TCP/IP commands over your local area network to control on-board relays. WiFi relay controllers are cross-platform compatible, as all operating systems are capable of sending and receiving TCP/IP data. WiFi is a popular choice for Android and IoS operating systems, as these WiFi relay controllers may be controlled in a standardized way. Below you will see just a few of our WiFi relay controllers:
Wireless Relays using Bluetooth Communications
NCD Bluetooth Relay Controllers are very popular for a wide range of mobile device communications applications. Capable of mounting as a COM Port on your PC, NCD Bluetooth relay controllers are very easy to use. Send command to control relays, flash relays, activate timers and counters, or read on-board analog inputs for sensor monitoring applications. Re-map the analog inputs for manual relay override applications. NCD Bluetooth relay controllers are the finest in the industry with a proven track record of usage in the world’s largest companies.
Key Fob Wireless Relay Controllers
NCD Key Fob Relay Controllers make it possible to remotely control all kinds of devices using a wireless remote control. Fully programmable, NCD Key Fob solutions make it possible to toggle relays on or off, flash relays, activate relays for a duration of time, as well as control relay groups with a single command. Ideal for Key Fob controlled gates, pumps, motors, valves, doors, windows, and much more. On-board inputs may be used for manual relay control applications. NCD Key Fob controllers make it possible to control relays of all types, from standard relays to high power and solid state relays.
Long Range Wireless Relay Controllers
NCD Manufactures Long Range Wireless Relay Controllers, capable of communicating up to 2 miles away from your computer using the included antennas! And up to 28 miles with high-gain antennas!
On-board analog inputs may be used for sensor monitoring and control applications over a long-range wireless connections. Monitor temperature sensors, switches, and other analog devices and control relays based on sensor inputs. On-board inputs may also be used to manually control relays when switches are pressed.
NCD ProXR series relay controllers offer an extensive command set for turning relays on or off, toggling the state of relays, activating relays for a duration of time, flashing relays on and off automatically and much more.
