NCD's Long Range Industrial IoT Wireless pH ORP Temperature Sensor
- Industrial Grade Wireless Dissolved Oxygen DO and Temperature Sensor
- DO Measurement Accuracy ±2%FS ±2°C temperature
- 3/4inch NPT connector Housing
- DO Range 0-20mg/L
- * USB Modem is recommended for Calibration and Sensor Setup
- Liquid DO
- Temperature
- Green House
- Agriculture
- Water Quality
- Industry Standard Measurement
- Waster Water Management
Introducing NCD’s Industrial IoT Long Range Wireless Dissolved Oxygen DO and Temperature Sensor, boasting up to a 2 mile range using a secure wireless mesh networking architecture. It incorporates a high resolution DO probe that samples liquid Dissolved Oxygen levels at user defined intervals and transmits the result to remote modems and gateways.
The Dissolved Oxygen DO probe for this sensor contains a built-in temperature sensor that will give temperature readings along with the DO data. This transmitter will send beacons of high-accuracy (±2%DO FS and ±2°C temperature) data at user-defined intervals with outstanding precision. The DO probe comes with a 5 meter long cable and has a 3/4 inch NPT housing. The probe is rated for 15°C to 60°C and can withstand a max pressure of 100 PSI.
This Industrial IoT Long Range Wireless Dissolved Oxygen DO and Temperature Sensor does require periodic calibration. The calibration period depends on the usage of the equipment. The calibration process can be done in house and the calibration steps can be found in the product manual. The probe can stay submerged in the liquid during its entire life span.
This Industrial IoT Long Range Wireless Dissolved Oxygen DO and Temperature Sensor is powered by just 6 AA batteries and has an operational lifetime of 300,000 wireless transmissions. 10 years of battery life can be expected, depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered, as it supports a 6-32 VDC external power supply.
- Industrial IoT Long Range Wireless pH and Temperature Sensor (with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
Sensor Type == 65
Wireless DO and Temperature Sensor
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x41 | ||||
| Reserved | 8 | error code |
DO | MSB 9/ Data[0] | – | DO Data DO% = (((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100.0) DO Saturation = (((Data[4]<<24)+(Data[5]<<16)+(Data[6]<<8)+Data[7])/100.0) | ||
| 10/Data[1] | – | ||||
| 11/Data[2] | – | ||||
| LSB 12/ Data[3] | |||||
| MSB 13/ Data[4] | |||||
| 14/Data[5] | – | ||||
| 15/Data[6] | |||||
| LSB 16/ Data[7] | |||||
| Temperature | MSB 17/ Data[8] | – | Temperature data Temperature(signed) = (((data[8] x 256) + data[9])/100)°C | ||
| LSB 18/ Data[9] | – |
Appendix A
Configuration Commands
15. Sensor DO Calibration
DO Clear Stored calibration
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 58 00 00 41 01 66
Command — F4 58 00 00 41 01
0xF4 — Header
0x58 — Sub command
00 — Node ID
00,41 — Sensor type
0x01 — Clear calibration
DO Atmospheric point Calibration Command
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 58 00 00 41 02 65
Command — F4 58 00 00 41 02
0xF4 — Header
0x58 — Sub command
00 — Node ID
00,00 — Sensor type
02 — DO ATM point calibration
DO Zero Point Calibration Command
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 58 00 00 41 03 64
Command — F4 58 00 00 41 03
0xF4 — Header
0x58 — Sub command
00 — Node ID
00,00 — Sensor type
03 — DO ATM point calibration
Read Calibration Status Command
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 59 00 00 41 66
Command — F4 59 00 00 41
0xF4 — Header
0x58 — Sub command
00 — Node ID
00,00 — Sensor type
DO calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- Drain out the old electrolyte and fill with fresh electrolyte
- Make Sure there are no air bubbles inside the electrolyte liquid
- Put the sensor in configure mode
- Put the DO probe in Zero DO and wait for few seconds
- Send the Zero Do calibration command
- Once the calibration is done sensor will send a response. This could take upto 10sec
- Remove the probe from the Zero DO and let it Dry out
- wait for 2 min
- Send Atmospheric calibration command
18. On Demand Data
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 32 00 00 00 01 CA
The Above command can be used to enable the on demand mode.
In on demand mode the devices stays power on all the time and waits for a command from the user. Once it gets the data request command from the user the sensor will compute the sensor values and responds with data.
This will drain the battery and only recommended when the device is powered up ll the time.
The on demand data request command-
Command For COPY: 7E 00 15 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 34 00 00 00 00 00 C9
On demand Disable –
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 32 00 00 00 00 CB
Command For COPY: Once sensor receives this command it will disable the on demand mode and go back to interval transmission mode.
19. Super Command
The super command can be used to configure some sensor parameters during run mode.
In order to set parameters like Delay, node id and other sensor related parameters the super command needs to be be enabled in the cfg mode.
Super command enable counter —
By sending this command users can set a counter after which sensor will stay awake for 2 sec and wait for a command from the user. if it does not get command withing 2 sec it will go back to sleep.
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 30 00 00 00 03 CA
In above command we are setting the super command enable counter to 3. After every 3 data transmission the sensor will stay awake for 2 sec and wait for any cfg command from the user.
Read super command counter Value
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 31 00 00 00 00 CC
Appendix B
- Keep only the last 8 bits
