- Industrial Grade Bidirectional Differential Pressure Sensor with Temperature output
- Operating Pressure Range -0.15 to 0.15 PSI
- Pressure Resolution 0.01 PSI
- Operating Temperature Range -25 to +85 °C
- Temperature resolution 0.01°C
- Small Form Factor (3×3 inch)
- Default Factory setting Restore option
- Real time battery status
- Wireless Differential Pressure Monitoring
- Fluid level Monitoring
- Medical Instrumentation
- Heating, Ventilation and Air Conditioning (HVAC)
- Component of a Low Power IoT System
- Home Automation and Control
Introducing NCD’s Wireless Environment Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It processes temperature and pressure data and transmits this information to user defined receiver(s). This whole process is repeated at user defined intervals with low power sleep mode activated in between. For technical details, please refer to the AMS5812 datasheet.
With an open communication protocol this sensor can be integrated with just about any control system or gateway. Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, or Arduino. Sensor parameters and wireless transmission settings can be changed on the go using the open communication protocol providing maximum configuration depending on the intended application.
The range, price, accuracy, battery life and security features of Wireless Bidirectional Differential Pressure Sensor makes it an affordable choice which exceeds the requirements for most of the Industrial as well as consumer market applications.
The Sensor and Zigmo/Router come pre-programmed and work out of the box. In this section we will setup a sensor and Zigmo link and start receiving data on our PC. Though this guide shows how to visualize data on LabVIEW utility, you can also use a simple serial terminal to see raw data by following these steps.
Note: This documentation is true for following products
- PR49-24M ( Sensor Type 21)
- PR55-24 ( Sensor Type 20)
- PR52-33P ( Sensor Type 26)
- IoT Long Range Wireless Pressure Sensor Bidirectional Differential (with power source Battery Or External DC)
- LabVIEW Utility for displaying sensor data (available on our website for free)
Note: The Wireless Sensor comes with external power enabled, for battery conservation during shipping. To enable battery power, open the enclosure and set the PS (power select) jumper which is parallel to the marking line on the board.
- Press the Run button to visualize incoming data.
Modes of Operation
- Run Mode
- Configuration Mode
Standard data transmission mode is the default mode of operation of this sensor. In this mode the sensor sends periodic packets to destination receiver. During the time it is not sending packets, it sleeps and conserves power. Sensor end X-bee operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 12 illustrates an API packet transmission and reception.
Typical response from the device in Standard data transmission mode is shown in Figure 13 and Figure 14. The utility shown in Figure 14 can be downloaded from the website.
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x15 | ||||
| Reserved | 8 | 0 | |||
| Pressure | 9/Data[0] | – | Pressure Data (16 bit Signed Output) Pressure (PSI) = ((Data[0]<<8)+Data[1])/100 | ||
| 10/Data[1] | – | ||||
| Temperature | 11/Data[0] | – | Temperature data (16 bit Signed Output) Temperature (°C) = ((Data[0]<<8)+Data[1])/100 | ||
| 12/Data[1] | – |
Industrial Wireless Absolute and Gauge Pressure Sensor
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| MSB 7 | 0x1A | ||||
| Pressure | 9/Data[0] | – | Pressure Data (16 bit Signed Output) Pressure (PSI) = ((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100 | ||
| 11/Data[2] | – | ||||
| 12/Data[3] | – | ||||
| Temperature | 13/Data[0] | – | Temperature data (16 bit Signed Output) Temperature (°C) = ((Data[0]<<8)+Data[1])/100 | ||
| 14/Data[1] | – |
Wireless Air Velocity Sensor
The detail for API packet received at PC end can be read from the X-bee manual available from Digi. The detail of the Payload section of packet is shown in Table 3.
The typical response from the device in Run mode is shown in Figure 13 and Figure 14. The utility shown in Figure 14 can be downloaded from the website.
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| MSB 7 | 0x1A | ||||
| Temperature Velocity | 13/Data[0] | – | Temperature data (16 bit Signed Output) Temperature (°C) = ((Data[0]<<8)+Data[1])/100 Velocity data (16 bit Signed Output) Velocity (m/sec) = ((Data[0]<<8)+Data[1])/1000 | ||
| 14/Data[1] | – | ||||
| 15/Data[0] | – | ||||
| 15/Data[1] | – |
Wireless Air Velocity Sensor HVAC
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| MSB 7 | 0x5B | ||||
| Pressure | 9/Data[0] | – | Velocity Data (16 bit Signed Output) Velocity (m/sec) = ((Data[0]<<8)+Data[1])/1000 | ||
| 10/Data[1] | – |
A standard configuration packet and its fields are explained in Figure 15. Its possible responses are also shown. The commands supported by this sensor are shown in Table 5, these can be used in the Parameters field of Payload section. The sensor responds to these commands with an acknowledgement if the process completed successfully or with an error if it failed to setup a parameter. The respective Data and Reserve section length and values are shown in Table 6 for the case of acknowledgement. In the case of error, the reserved section will be fixed and not used, while the Error number byte will determine the type of error returned. These errors are mentioned in Table 7.
Examples for setting parameters in configuration mode are shown in Appendix A. Note that incorrectly setting some of the critical settings such as setting PANID and Destination address can disable further communication between a Zigmo and the sensor. Hence, these settings are saved in the sensor but they take affect after a reset so that the communication is not lost.
The UI, shown in Figure 16, can be used to configure the wireless sensor. At startup, it automatically changes the Zigmo PANID so that it can communicate with a sensor in configuration mode (indicated by the Led on the top right). Upon exit, the PANID of the Zigmo is restored to old value.
Appendix A
Configuration Commands
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0015 E7
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0015 0000 0004 E2
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0015 1234 5678 D1
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0015 02E2
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0015 7BCD 9B
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0015 0BD7
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0015 D3
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0015 D2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0015 D1
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0015 D0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0015 CF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0015 EC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0015 EB
Command For COPY: 7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0015 0011 2211 2211 2211 2233 4433 4433 4433 4442
Appendix B
- Add all the bytes and keep the lower 8 bits of result (Excluding the frame delimiter and length)
- Append this byte at the end of the original packet for sending
- Add all the bytes including the received checksum (Exclude the frame delimiter and length)
- Keep only the last 8 bits
