WiFi Micro Gateway Setup for MQTT
Shipping Delays due to Covid:Â PLEASE CLICK HERE. Dismiss
NCD5500 Ethernet Module Web Interface User Guide
Jacob Youngblood, , Uncategorized, 0
About the Web Interface TODO Rework Figure 1 The NCD5500 allows you to easily change from a simple TCP socket or UDP datagram communication architecture over to a web interface based control and monitoring system. This interface is usable out of the box or completely customizable using HTML, CSS, and JS. Compatibility Currently the Web Interface configuration of the NCD5500 Ethernet module is only compatible with ProXR Lite. Getting Started Step ...
Google IoT Core Gateway Setup
TravisE NCD Technical Engineer, , Uncategorized, 0
Google IoT Core G A T E W A Y  S E T U P Introduction The Google IoT Core Gateway was designed to make setup as simple as possible. In this guide we will walk through setting up a new Google IoT Core gateway. It is not the intent of this guide to explain how to consume device data on Google cloud, but rather to simply get the data there so you can consume it as needed. This guide will walk you through creating: • A Google Cloud Project â€...
How To Bring Legacy Machine to IoT Connected World
Bhaskar, , Uncategorized, 0
How To Connect Legacy factory Equipment With Modern Day IoT World Choosing a IoT Upgrade Strategy How the IoT Can Assist Primitive Machines on the Factory Floor How to Upgrade Factory Machines for IoT Connectivity Why Choose RS485-Wireless Trans receiver Replace RS485-Modbus Wires with a Wireless Link How To Convert Wired RS485 Sensors in Wireless Sensors How To Connect Legacy factory Equipment With Modern Day IoT World By now, we already know th...
4-20mA 4 Channel Mirror Product Manual
Introduction The purpose of this manual is to educate users on the functionality and use of the 4 channel Wireless 4-20mA Mirror Pro product. Â Please contact us with any questions you may have on the use of this product. Power Requirements These products are sold with optional power supplies which are recommended for use with the product. Â If you must supply your own power supply to the devices then a regulated 9-32VDC power supply source capab...
What is nodeLynk? The nodeLynk I2C Communications Standard
Ryan, , Uncategorized, 0
What is nodeLynk I²C Communication?​ https://media.ncd.io/20190612110234/NodeLynk-Vid-3.mp4 nodeLynk I²C is a physical I²C communications bus standard developed by National Control Devices in 2014. nodeLynk devices use I²C communications to communicate between an I²C Master device and a chain of I²C Node devices. nodeLynk I²C is a physical standard that does not alter the I²C communications protocol in any way. If you are already fa...
Top 3 Motor Failure Detection Sensors & Benefits
Top 3 Motor Failure Detection Sensors It’s no secret that motors run our lives. But some motors are far more important than others, and in some cases, motor failure is not an option. Keep in mind, we rely on motors to run the cooling systems in nuclear reactors. We rely on motors to run elevators in high-rise buildings. Motors keep fuel flowing into jet engines of our airplanes. There’s a lot riding on today’s motors, an...
endNode Memory Map
endNode Memory Map The endNode Memory Map helps users identify important FRAM memory locations in a endNode controller. The Memory Map editor/viewer is accessed from Alpha Station. We built this editor to help develop endNode devices as it’s important to see what’s happening in memory during the design process. We elected to share this tool with our users so they can get the most out of endNode devices. We typically don’...
Contact Closure Email Generator User Guide
Introduction In this guide we will cover the functionality and use of the Contact Closure Email Generator. We will cover basic requirements, hardware functionality, configuration, and troubleshooting of the device. Basic Requirements Email Broker This device communicates directly with your Email Broker via the SMTP protocol. Â Most Email Brokers such as Gmail and Outlook support SMTP connectivity so this device is compatible with most Email broke...
