WiFi Micro Gateway for Microsoft® Azure®
Setup Instructions
The NCD WiFi Micro Gateway allows the complete line of NCD sensors to communicate over the internet to Microsoft Azure using a WiFi connection. The NCD Micro Gateway is very easy to use, as it only requires network connection credentials and an Azure Connection String. All sensors are fully encrypted using 128-bit AES encryption. WiFi communications is also fully encrypted for your security. To get started using the WiFi Micro Gateway, follow the steps outlined below.
Gateway Setup and Installation
Remove the NCD WiFi Micro Gateway from the packaging and carefully install the antenna. The antenna screws onto the side of the gateway. Please DO NOT OVER-TIGHTEN or damage will result.
Plug the WiFi Micro Gateway into any available outlet to power it up using the included power supply. The Internal LED should be flashing blue. If the Internal LED is not flashing blue, follow these steps (Otherwise, Skip to Step 3):
a. Open the Gateway enclosure to expose the RED configuration button. Hold button down until the internal LED flashes blue.
b. Press and release the exposed configuration button and secure the top cover the WiFi Micro Gateway.
With the internal LED flashing blue, use a SmartPhone or Laptop Computer to change your WiFi Connection Settings. A new network will appear called “WiFi_Micro_Gateway”. Associate your mobile device with this new WiFi Network.
The LED should be solid green once WiFi connection is established and the gateway is connected to Azure.
The LED will slowly flash between a dim white color and red if there was a problem associating the NCD WiFi Micro Gateway to your network. If you were unable to associate the gateway, make sure you have entered the correct WiFi password and Azure connection string.
Sensor Setup and Installation
Now that the Gateway is communicating to Azure, it’s time to power-up your remote sensors. Follow the steps shown below to enable NCD Sensors:
NOTES
NOTE: These sensors are secured using the default NCD 128-Bit AES encryption key. This is the same Key used by ALL NCD Wireless Sensors at the time of shipping. Please contact us if you would like a custom Key Assigned to your company. We have also made provisions for customers to change the Encryption Key using additional hardware.
ncd.io
