USB Relay Controllers
Features of USB Relays
USB Relays provide the most stable method for controlling relays in almost any application, and are available on most of our product lines.
- Simple implementation
- Interface mounts as virtual COM port
- Compatible with any operating system
- Industry Leading Command Set
- Send Specific Commands to Trigger Relays
- Trigger Any or All Relays
- Program in any Language
- Wide Range Of Option
- 1,2,4,8,16 USB Relays Controller
- 24,32,64 Channel USB Relays Module
- USB Relay Module With Analog Inputs
- USB Relay Controller With GPIO Digital I/O
- Base Station Software
- Point & Click Interface
- Read Sensor Levels
- Read Status of Relays
- Manually Trigger Relays
Our USB Relays
Our full line of USB compatible controllers suit nearly any application, and our USB modules come with a long history of proven stability. Customize your project with exactly the options you need. From General Purpose, High Power or Signal Switching, we have you covered with our SPDT, DPDT, and SPST Relays. The versatility of our USB relay controllers ensures an easy and reliable solution to whatever your switching needs.
USB Relay Controllers with 16 or More Relays
NCD manufactures the largest USB Relay controllers in the world, with options for 16, 24, 32, 48, 56, and 64 on-board relays. Expansion options allow NCD relay controllers to scale up to 256 channels. Dual interface options are also available on the Fusion series controllers, allowing two USB ports to control the entire array of on-board and off-board expansion relays.
Why Choose NCD?
How It Works
All USB Relay Controllers are equipped with our proprietary firmware built into the board. This will allow you to Control one relay at a time, a bank of relays or all relays at once with manual and automatic refreshing command set. You can send commands can be sent over the virtual COM port, or our Base Station software. We make integrating into existing systems, or building entirely new ones quick and painless.
