Wireless Temperature Sensors
Sensors Made Simple
Our plug and play temperature sensor design allows you to connect any sensor with any platform. Arduino, Raspberry Pi, Onion and more with no soldering required. We have a full line of temperature sensors to fit your application’s needs. Our chainable design allows you to easily add additional monitoring and control hardware in seconds.
- Plug and Play I2C Communications
- Cross Platform Ready
- Chainable Sensor and Control Options
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
been an industry leader for more than 26 years.
Our I²C Wireless Temperature Sensors
We have a full line of temperature sensor options able to cover almost any application. We have low temperature sensors, high temperature sensors, and k-type thermocouples. Some of them have humidity, altitude, and acceleration readings available as well. When it comes to sensors, we’ve got what you need.
Industrial IoT Long Range Wireless pH and Temperature Sensor
$681.95 - $715.95
$282.95 - $303.95Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform using the adapter. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples. We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the sensor like it was built into your platform.
About I²C
I²C is a high speed communication bus popular in electronic monitoring and control applications. As it pertains to our devices you only need to worry about sending and receiving data. Each platform/language has its own library for communicating over I²C that will greatly simplify you application. Once you have that library imported you can start reading and writing data in a few minutes using our libraries and code samples as a basis.
IoT or Embedded?
IoT Options
- Raspberry Pi (powerful platform, clouds: blink, IFTTT)
Local or Embedded
