Temperature and Humidity Sensors
Sensors Made Simple
Our plug and play Temperature and Humidity Sensor design allows you to connect any sensor with any platform. Arduino, Raspberry Pi, Onion and more with no soldering required. We have a full line of Temperature and Humidity sensors to fit your application’s needs. Our chainable design allows you to easily add additional monitoring and control hardware in seconds.
- Plug and Play I2C Communications
- Cross Platform Ready
- Chainable Sensor and Control Options
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
Our I²C Temperature and Humidity Sensors
We have a full line of Temperature and Humidity sensor options able to cover almost any application. Some of them have altitude or acceleration readings available as well. When it comes to sensors, we’ve got what you need.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform using the adapter. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples. We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the sensor like it was built into your platform.
About I²C
IoT or Embedded?
IoT Options
- Raspberry Pi (powerful platform, clouds: blink, ifttt)
Local or Embedded
