Raspberry Pi Relays
Any Relay, Any Platform
We designed our boards to be instantly compatible with any platform. For Raspberry Pi we have shields that will give a simple plug in to connect to any of our IoT line of boards. All you have to do is add the adapter for your version of the Raspberry Pi as an add-on and you’re ready to go.
- Raspberry Pi 1, 2, and 3 compatible
- Plug and Play connection
- Plug and Play sensor and control expansions
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
Our Raspberry Pi Relays
We have a full line of Raspberry Pi Relay options able to cover almost any application. Choose from high power relays, signal relays, mechanical relays, solid state relays, SPDT, DPDT, SPST, and more. NCD has been making relay controllers for more than 20 years. We know relays.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform.
About I²C
I²C is a high speed communication bus popular in electronic monitoring and control applications. As it pertains to our devices you only need to worry about sending and receiving data. Each platform/language has its own library for communicating over I²C that will greatly simplify you application. Once you have that library imported you can start reading and writing data in a few minutes using our libraries and code samples as a basis.
IoT or Embedded?
IoT Options
Local or Embedded
