Raspberry Pi Analog Output 4-20mA Current Loop Transmitter
Raspberry Pi 4-20mA Current Loop Output
Industrial grade Isolated Raspberry Pi Analog Output 4-20mA current Loop Transmitter with on board power management and signal, power isolation. Ideal current loop output interface board for raspberry Pi. Control up-to 2 4-20mA current loop input sensor using one board. Plug and play architecture.
- Raspberry Pi 1,2,3 4-20mA Current Loop Transmitter
- Raspberry Pi Zero 4-20mA current Loop Transmitter
- Plug and Play connection
- Plug and Play sensor and control expansions
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
If you are looking for a low-cost high-accuracy industrial 4-20mA current loop transmitter to interface with your Raspberry Pi or any other single board computer, Linux computer, Windows computer. In that case this is the ideal product for you. This isolated 4-20mA current loop transmitter board comes with on board power as well as signal isolation. This can be used to control solenoids, analog output pumps, valves and much more. This 4-20mA Analog output board is real easy to interface with Raspberry Pi, all you will need is a Raspberry Pi I²C shield, I²C cable.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform.
About I²C
IoT or Embedded?
IoT Options
Local or Embedded
