Raspberry Pi 4-20mA Current Loop Receiver
Raspberry Pi 4-20mA Current Loop Input
Industrial grade Raspberry Pi 4-20mA current Loop receiver with on board power management. Ideal current loop input interface board for raspberry Pi. Read up-to 4 4-20mA current loop output sensor using one board. Plug and play architecture.
- Raspberry Pi 1,2,3 4-20mA Current Loop Receiver
- Raspberry Pi Zero 4-20mA current Loop Input
- Plug and Play connection
- Plug and Play sensor and control expansions
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
If you are looking for a low-cost high-accuracy industrial 4-20mA current loop receiver to interface with your Raspberry Pi or any other single board computer, Linux computer, Windows computer. In that case this is the ideal product for you. This 4-20mC current loop receiver board comes with on board 16V power supply and has 16 bit resolution. This can be used to read RTD temp sensors, float sensor, distance sensor, water level sensor, 4-20mA power monitors. This 4-20mA board is real easy to interface with Raspberry Pi, all you will need is a Raspberry Pi I²C shield, I²C cable and 4-20mA current input board.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform.
About I²C
IoT or Embedded?
IoT Options
Local or Embedded
Visit home to read more about NCD’s Industry specific articles.
