Raspberry Pi 0-10V Analog Output Module
Industrial grade Raspberry Pi Analog Output 0-10V DAC Module. Ideal for controlling analog input devices using this 0-10V DAC module. Easy interface with Raspberry Pi or any other embedded computer. Plug and play architecture.
  • Raspberry Pi One Channel 0-10V Analog Output
  • Raspberry Pi Zero 0-10V Digital To Analog Converter
  • 12 Bit Resolution
  • On Board Boost Power Supply
  • On Board Signal Conditioning Amplifier
  • Plug and Play connection
  • Plug and Play sensor and control expansions
  • Compatible with:
    • Particle
    • Many More
If you are looking for a low-cost high-accuracy industrial Raspberry Pi 0-10V Analog Output Boards to interface with your Raspberry Pi or any other single board computer, Linux computer, Windows computer. In that case this is the ideal product for you. This 0-10V DAC  output board comes with on board regulated 5V power supply and has 12 bit resolution. This 0-10V DAC output Shield can be used to control lights, Pumps,, solenoids,PLC and much more devices which need 0-10V Analog to control  . This 0-10V Analog  output Shield is real easy to interface with Raspberry Pi, all you will need is a Raspberry Pi I²C shield, I²C cable and 0-10V DAC output board.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform.
About I²C
I²C is a high speed communication bus popular in electronic monitoring and control applications. As it pertains to our devices you only need to worry about sending and receiving data. Each platform/language has its own library for communicating over I²C that will greatly simplify you application. Once you have that library imported you can start reading and writing data in a few minutes using our libraries and code samples as a basis.
IoT or Embedded?
IoT Options
  • Particle (easy to use cloud, excellent web IDE, wifi or cellular comms)
  • Onion Omega (built on linux, quick cloud connectivity)Ā
  • Raspberry Pi (powerful platform, clouds: Blink, IFTTT, Azure)
Local or Embedded
  • Arduino (proven platform, simple coding)
  • Raspberry Pi (power platform, choose your own coding language)
Visit homepage if you are interested to know the overview of product categories and other industry related important article.
